IP Profile
- IP Profile
IP Profile
08-02-2011 10:59 AM
Could one of the PN people give my IP Profile a nudge to the max please(7k +) as it's currently at 5500 and sync is 6784kbps since some local exchange problems I suspect of up/down about 4days ago?
Question #39595686
Re: IP Profile
08-02-2011 11:55 AM
your SNR is currently 12dB which will be making your sync and consequently the IP profile slightly lower. Can you confirm that you are not using extension sockets/cables and are you able to try plugging into the test socket?
Jojo
Re: IP Profile
08-02-2011 12:29 PM
Normally snr is 11dB and cabling is on an extension and fine before. Just don't want to power anything off yet in case it interferes with BLIP logic
Been sync'ing at 8128kbps for years.
Re: IP Profile
08-02-2011 5:20 PM
I appreciate it's been ok like that but we can't really diagnose problems in an extension socket as the first thing we have to do is rule out any internal issues.
Jojo
Re: IP Profile
08-02-2011 7:03 PM
Re: IP Profile
08-02-2011 8:23 PM
It's possible your sync speed might increase when you re-sync, depends what target noise margin the DLM has set. If your sync speed does increase it can take up to 5 days for the IP Profile to increase again. Not sure if blip logic still applies but in any case I think it comes into play only if the sync speed is restored before the Profile has reduced.
Re: IP Profile
14-02-2011 9:10 PM
I am due an FTTC upgrade on 17/02/11 but today connected router to master socket and got 704xkbps sync with still 15db SNR down and then increased upstream from 22 to 27dB. I do believe there is some issue with the exchange as get a drop out now and then which the log sometimes picks up (today at 2000hrs) and some which don't as it's very brief.
I hope this has no effect on me when I am transferred to FTTC?
Re: IP Profile
15-02-2011 9:12 AM
Do you mean master socket or test socket. There are lots of things that could cause that so wouldn't like to say what it would be right now.
Jojo
Re: IP Profile
15-02-2011 12:48 PM
Removed cover from master socket and used test socket behind which gave the slightly higher sync and also have a new microfilter.
As I say, I am hoping the problem being downstream won't affect FTTC but would be nice to get this pinned down though given the time left unlikely I imagine.
Quote System Up Time 15:08:22
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 92450 129292 0 322 2665 15:07:51
LAN 10M/100M 139043 117934 0 2758 398 15:08:17
ADSL Link Downstream Upstream
Connection Speed 6848 kbps 448 kbps
Line Attenuation 11 db 2 db
Noise Margin 12 db 20 db
Re: IP Profile
16-02-2011 8:40 AM
I think you would probably get full speed if it weren't for the SNR. I wouldn't imagine you'll have any trouble once the FTTC is installed though.
Jojo
Re: IP Profile
16-02-2011 3:30 PM
The SNR sits around 11/12dB in the past. Wonder if BT have changed the noise margin at the exchange after the recent outage and set to 15dB instead of 6dB?
Will the FTTC product use different equipment at the exchange so not to have any issue with 20CN 'speed reduction' affecting the new product?
Re: IP Profile
16-02-2011 4:38 PM
Basically the fibre will go from the exchange to the cabinet and your pair at the cabinet will be wired into the fibre. This means that you will not be affected by any issues there may have previously been between the cabinet and the exchange.
Jojo
Re: IP Profile
16-02-2011 9:40 PM
Here's hoping for a seamless transition tomorrow A.M. and have router setup and route for CAT5E/6 cable from Master socket to upstairs where Router is to be situated. prepp'd and very organised
Thanks Plusnet for getting the router here in time and the communication (texts) sent - nice!
Re: IP Profile
17-02-2011 10:25 AM
Re: IP Profile
17-02-2011 10:26 AM
