IP Profile
- IP Profile
Re: IP Profile
29-06-2010 9:44 AM
Re: IP Profile
30-06-2010 2:16 PM
Re: IP Profile
30-06-2010 4:26 PM
I've just checked and the banded profile is still in place. I will check again for you in the morning.
Jojo
Re: IP Profile
30-06-2010 5:04 PM
Re: IP Profile
01-07-2010 5:00 PM
Re: IP Profile
02-07-2010 9:40 AM
I updated my ticket yesterday but have heard nothing to date. Could you possibly check it out for me? Stats are pretty much unchanged with no disconnections.
Download speed achieved during the test was - 5286 Kbps
For your connection, the acceptable range of speedsis 1000-7150 Kbps.
Additional Information:
Your DSL Connection Rate :6652 Kbps(DOWN-STREAM), 444 Kbps(UP-STREAM)
IP Profile for your line is - 5500 Kbps
Line Up Time 06:11:36:13
Statistics Downstream Upstream
Line Rate 6653 Kbps 444 Kbps
Noise Margin 15.1 dB 27.9 dB
Line Attenuation 30.0 dB 13.9 dB
edit::
Just had a response to my ticket telling me to keep my modem switched on and my speed will increase over the next few days. Does this mean my banding has been removed?
Re: IP Profile
02-07-2010 10:14 AM
Jojo
Re: IP Profile
02-07-2010 10:17 AM
Re: IP Profile
02-07-2010 11:12 AM
Jojo
Re: IP Profile
02-07-2010 1:08 PM
Thanks for that. As far as I was aware Interleaving was 'on' anyway. It was in the past and I have never requested it to be turned off. I hope this is sorted before my next billing date on the 21st as if I continue on these speeds I may as well switch to Plusnet Value as I can manage with a 10GB peak time allowance.
Re: IP Profile
05-07-2010 9:26 AM
Re: IP Profile
05-07-2010 10:02 AM
Just to keep you updated, we're checking up to see how the errors are going now. I'll keep you posted as soon as I know more.
Jojo
Re: IP Profile
05-07-2010 10:09 AM
Re: IP Profile
05-07-2010 1:50 PM
all seems ok now so it should get removed today. I'll check it out a bit later and see if it's been done.
Jojo
Re: IP Profile
05-07-2010 1:59 PM
