IP Profile
chrisoldinho
IP Profile
Hi - my IP profile was upped to 2000kbps last night. Is it possible for PN to increase their end to match as i'm stuck at 500kbps at present.
Thanks! Smiley
Chris.
gofaster
Re: IP Profile
Could someone give mine a nudge too. Since moving to ASDL2+ I am synching at 11M and the BT speedtester reports my profile as 10M but my Plusnet profile is set to 8.
Could my upload speed cap be removed as well? I seem to be stuck at 439kbps.
Re: IP Profile
@chrisoldinho - done Smiley
@gofaster - likewise done, I've also placed the order to uncap the upstream. That should complete for you tomorrow.
chrisoldinho
Re: IP Profile
Thanks Matt - is it possible for my upstream to be uncapped or is there a restriction on this?
Thanks, Chris
r3fl3x
Re: IP Profile
Hi Matt - could my profile be nudged too please? Synching at 11.2 with BT Profile at 9 after some router config tweaks.
Can I also have my upload uncapped? I wonder whether it is capped or not writing this but it can't hurt.
/ADSL n00b.
Re: IP Profile
@chrisoldinho - yep, done and should complete tomorrow.
@r3fl3x - profile now set to 9000 and order placed to uncap the upstream.
r3fl3x
Re: IP Profile
Matt - thank you very much. You do a fantastic job on these forums!
chrisoldinho
Re: IP Profile
Thanks Matt for you're help - can't wait Smiley
Just a couple of other questions if I may - Will uncapping the upstream affect the downstream sync / download speed and by uncapped upstream is it truly "uncapped" and is there a typical upstream increase I can expect?
Thanks, Chris.
Re: IP Profile
Hi Chris,
It shouldn't affect the downstream sync (unless the line is long and unstable, in which case it tends to use some of the available upstream bandwidth for downstream if need be). I'd expect you to get around 1Mb upstream once the order completes.
chrisoldinho
Re: IP Profile
Excellent - Thanks Matt.
chrisoldinho
Re: IP Profile
Hi Matt -Can you confirm my upstream is now uncapped as i'm still only getting 440kbps upstream.
Is it only available on Annex M connections as mine is Annex A?
gofaster
Re: IP Profile
Can I say "Me too" again?
Although my upstream synchseems to have changed from 439kbps to 444kbps, I was hoping for something more dramatic than that.
Re: IP Profile
@chrisoldinho - Due for the 13th for some reason. Sorry about that.
@gofaster - Yours should complete on the 12th.
Sorry about that, I used an automated tool to place the orders rather than doing it manually - I suspect that's the cause of the long lead time.
