IP Profile
stordoff
IP Profile
Anyone know how to check my current IP Profile? The portal shows "Your current broadband speed is Not Set Kbps" and the BT Speedtester site seems premenently busy, I have tried a number of times through the day
Fixes: 234
Re: IP Profile
These I think are the only 2 places that I know of to check your IP profile.
I've just used the BT one myself and it worked ok, may be worth trying again?
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
stordoff
Re: IP Profile
No, BT still says it is busy. I don't think that I have every had it working the entire time I have been with PlusNet
Re: IP Profile
The BT tester has never once worked for me either!
All I ever get is: "The login name entered on this tool doesnt match that discovered by querying the network for your domain name. Please check your telephone number (or user name) and try again. If problem persists please contact your CP."
Re: IP Profile
What login name are you using? It should be the one in your router configuration (e.g. something@plusdsl.net).
Re: IP Profile
Yeah it is that one I'm using, always has been!
stordoff
Re: IP Profile
Put my phone number in, and almost straight away get:
"The system is currently busy. Please try again shortly, however if this problem persists, raise the issue with your service provider."
I use ...@plusdsl.net to login
puddy
Re: IP Profile
I use jpHuhs@f9.co.uk but i am with force9
Only time I got it working was in the early hours of day i.e a sleeply 3.30am
puddy
pierre_pierre
Re: IP Profile
just done one on freeonline.net, no problem
Test1 comprises of Best Effort Test:  -provides background information.
    IP profile for your line is - 6500 kbps
    DSL connection rate: 448 kbps(UP-STREAM)  8096 kbps(DOWN-STREAM)
    Actual IP throughput achieved during the test was - 5527 kbps
MickKi
Re: IP Profile
Early in the morning/late at night is usually OK.  Most other times you are likely to fail.
pierre_pierre
Re: IP Profile
well why not try now? i did  looks ok to me
stordoff
Re: IP Profile
I've tried at all times of the day, including early in the morning. (~2am) Still get a busy message
Re: IP Profile
Which browser are you using?
It only works for me with IE
pierre_pierre
Re: IP Profile
I am using Firefox on XP2 no problems yesterday , no problem now either now Bobboobly is also moaning, how come I have no trouble
    Actual IP throughput achieved during the test was - 5807 kbps
Voyager 2110
Re: IP Profile
Hmm, I wonder why it Firefox never worked for me...Santiago goes to try BT speedtester with Firefox
