IP Profile
rld
IP Profile
I should be getting at least 74Mbs but only getting around 33Mbs. How do I have my IP Profile reset to match?
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: IP Profile
Hi rld,
It looks as though some of the settings on our system was set incorrectly. Can you log into your router and click 'Disconnect' and then 'Connect' again, this should resolve the issue for you.
Chris Pettitt
Cloud Environments Engineer
rld
Re: IP Profile
Thanks Chris, that sorted the problem out.
