IP Profile
- IP Profile
IP Profile
04-07-2013 7:24 AM
Hi, recently upgraded my package to upto 80mb ran bt speed test and I am getting roughly the same speed as I was on upto 40 mb, bt speed test reports my ip profile is set at 51.11 is this correct? or do you guys have to do something at your end to change my ip profile ?
Regards
Phil
Regards
Phil
Message 1 of 4
(765 Views)
3 REPLIES 3
Re: IP Profile
04-07-2013 7:28 AM
The BT IP profile indicates that you are on 80Mb/s (it's above 40Mb, though not by an enormous amount).
You can check the Plusnet profile 'Current Line Speed' here: https://portal.plus.net/my.html?action=data_transfer_speed (requires login), this should be just below the BT IP profile.
Call me 'w23'
Message 2 of 4
(372 Views)
Re: IP Profile
04-07-2013 7:47 AM
Hi thanks for speedy reply
Cheers
Phil
Cheers
Phil
Message 3 of 4
(372 Views)
Re: IP Profile
04-07-2013 1:17 PM
You're syncing at roughly 53Mb which has given you a profile of 51.11Mb. I've replicated this on our side to make sure we're not incorrectly profiling you.
Message 4 of 4
(372 Views)
