IP Profile
- IP Profile
IP Profile
25-11-2009 6:10 PM
My Ip Profile is currently 5500.
I have a stable connection and live close to the exchange and used to get 6.5mb + speeds with Sky Connect (Old Bb Provider)
My question is can my ip profile be raised ? im a noob to these things, had interleaving turned off and getting 5.2mb download from SpeedTest.Net, just think my connection could be better. Im with PlusNet Pro if that helps.
Thanks..
Thanks..
Message 1 of 8
(1,240 Views)
7 REPLIES 7
Re: IP Profile
25-11-2009 6:24 PM
We need your router line stats before we can help. Thats line attenuation, SNR/noise margin and sync rates.
What does Data Transfer Speed say?
Message 2 of 8
(580 Views)
Re: IP Profile
25-11-2009 6:26 PM
Estimated line speed:
6 - Checked on 2009-11-25 13:04:06
Current line speed:
5500
Current line speed:
5500
Message 3 of 8
(580 Views)
Re: IP Profile
25-11-2009 6:32 PM
and your line stats?
Message 4 of 8
(580 Views)
Re: IP Profile
25-11-2009 6:36 PM
Link Information
Uptime: 0 days, 4:32:43
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 6,656
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 10.5 / 19.0
SN Margin (Up/Down) [dB]: 24.0 / 15.0
Vendor ID (Local/Remote): TMMB / TSTC
Message 5 of 8
(580 Views)
Re: IP Profile
25-11-2009 6:39 PM
Looks like your downstream SNR has been set to 15dB which is affecting your sync rate. Have you been resetting / disconnecting your router recently as that can cause the exchange to think you have a bad line and increase the Min SNR.
If the SNR is stable then raise a ticket to get your Min SNR reduced to 6dB and your sync rate should increase.
Message 6 of 8
(580 Views)
Re: IP Profile
25-11-2009 6:41 PM
Reset my router once or twice today but i dont think that would be the problem, will i make a ticket ?
Message 7 of 8
(580 Views)
Re: IP Profile
25-11-2009 6:50 PM
Rasied a ticket, hopefully it gets sorted out
Message 8 of 8
(580 Views)
