IP Profile stuck?
- IP Profile stuck?
IP Profile stuck?
07-12-2008 4:44 PM
I seem to have a similar issue to some other people with my IP profile being stuck at a low speed on the plusNET end.
I've just run a BT speedtest that gave the following info#:
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 3616 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 2000 kbps
Actual IP throughput achieved during the test was - 1838 kbps
My router has been syncing at above 3000 kbps for at least a week, yet it hasn't changed the IP profile for some reason. Speedtests show a download speed of 1.8 Mbps as per the profile.
Can my IP profile be set to 3000 kbps or higher please?
Message 1 of 2
(842 Views)
1 REPLY 1
Re: IP Profile stuck?
07-12-2008 9:12 PM
AFAIK PlusNet don't have any control over the IP Profile that BT set only what appears in the member centre here https://portal.plus.net/my.html?action=data_transfer_speed
Are you sure there have been no points where you have had a synch under 2848 in the past few days?
Message 2 of 2
(335 Views)
