IP Profile stuck at 40Mbps?
- IP Profile stuck at 40Mbps?
20-10-2013 2:15 PM
Is it possible my IP Profile is set to 40Mbps? According to the BT Wholesale Speed Test my IP Profile is 40.86Mbps. But I thought it should be 80Mbps? The estimated line speed was 54Mbps when I signed up and am getting currently 39Mbps.
Message 1 of 2
(566 Views)
1 REPLY 1
Re: IP Profile stuck at 40Mbps?
21-10-2013 12:53 PM
It doesn't appear to be a 40mbs profile. Diagnostics are showing me an up-to 54mb profile. 80mb would relate to the fibre product (which you are definitely on) rather than a profile.
If that doesn't improve you might want to raise a fault: http://faults.plus.net
Adam
Adam
Message 2 of 2
(303 Views)
