IP Profile reset?
- IP Profile reset?
- « Previous
- 1
- 2
- Next »
Re: IP Profile reset?
05-10-2013 4:42 PM
05-10-2013 4:44 PM
Wish I could get fibre 😞
05-10-2013 5:43 PM
Quote from: Damian78 The annoying thing is I'm on a new and developing housing estate and can just about see the Green cabinet from my house. The cabling is all underground and about 2 years old.
That's somewhat irrelevant I'm afraid. It's your distance from the exchange that's the problem. Your line is attenuated too much to handle a low margin. Openreach don't recommend a 3dB margin unless you're within 1K of an exchange (that's what a BTO engineer told me). You're attenuation (49dB) suggests you are just over 3.5K away.
05-10-2013 6:04 PM
Assuming we will get Fibre (another 200 homes planned to be built plus a pub) will this become irrelevant? Assuming we are deemed "economically viable"?
Plus....used to get about 6.5mgps. Is that possible on a higher SNR?
05-10-2013 7:55 PM
Quote from: Damian78 Plus....used to get about 6.5mgps. Is that possible on a higher SNR?
I'm afraid not.
05-10-2013 7:59 PM
Quote from: Damian78 Assuming we will get Fibre (another 200 homes planned to be built plus a pub) will this become irrelevant? Assuming we are deemed "economically viable"?
Not completely, but a lot less, yes. FTTC (which you will most likely get) is fibre to the 'cabinet' (the green boxes you see by the road) and then a phone line to your house. Effectively therefore, your line becomes as long as the distance to the cabinet.
If you put your phone number in here (https://www.btwholesale.com/includes/adsl/main.html) you can see if your cabinet is planned to have fibre. In addition, if you put your phone number in here (http://www.samknows.com/broadband/exchange_search) you can see if FTTC is planned at your exchange.
05-10-2013 8:01 PM
Don't see fibre in my area soon 😞
06-10-2013 10:18 AM
DSL Connection
Link Information
Uptime: 0 days, 17:33:09
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1,064 / 7,435
Data Transferred (Sent/Received) [MB/MB]: 42.97 / 621.78
Output Power (Up/Down) [dBm]: 12.8 / 0.0
Line Attenuation (Up/Down) [dB]: 27.5 / 49.0
SN Margin (Up/Down) [dB]: 4.6 / 2.5
Loss of Framing (Local/Remote): 8 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 444 / 0
FEC Errors (Up/Down): 0 / 250,931,719
CRC Errors (Up/Down): 100 / 942
HEC Errors (Up/Down): 44 / 5,209
Can someone from Plusnet reset this to 6dB?
07-10-2013 12:32 PM
07-10-2013 12:38 PM
The ping has increased though?
Oh and its about 5.1dB now. If it remains stable at that speed I can live with it.
10-10-2013 8:43 PM
Link Information
Uptime: 0 days, 7:34:42
Bandwidth (Up/Down) [kbps/kbps]: 1,085 / 7,435
Data Transferred (Sent/Received) [MB/MB]: 35.24 / 272.52
Line Attenuation (Up/Down) [dB]: 27.4 / 49.0
SN Margin (Up/Down) [dB]: 5.5 / 1.4
Error Seconds (Local/Remote): 303 / 0
FEC Errors (Up/Down): 2,695 / 3,227,734
CRC Errors (Up/Down): 125 / 461
HEC Errors (Up/Down): 135 / 3,259
Gone nuts today.
Role on 13/10!!
10-10-2013 10:32 PM
Modulation : ADSL2+
Annex Mode : Annex A/L
Line State : up
Lan Tx : 31207566
Lan Rx : 29722850
ADSL Tx : 3352249
ADSL Rx : 4616707
CRC Down : 0
CRC Up : 156
FEC Down : 0
FEC Up : 319
HEC Down : 362
HEC Up : 0
SNR Up : 6.2
SNR Down : 6.1
Line Attenuation Up : 3.9
Line Attenuation Down : 8.0
Data Rate Up : 1051
Data Rate Down : 18524
11-10-2013 10:33 AM
I've requested the reset for you, should take effect within the next few hours - hope it gets you back up to your previous speed.
- « Previous
- 1
- 2
- Next »
