IP Profile reset?
- IP Profile reset?
IP Profile reset?
29-09-2013 12:29 PM
A few months ago my router went nuts, dropping connection like crazy.
Had the replacement router now for sometime with a very stable connection but my speed had dropped slightly as my IP profile has reduced.
Tried going through the Plus nets broadband faults procedure but got no where. Can my line be reset or IP Profile reset?
Re: IP Profile reset?
29-09-2013 5:56 PM
29-09-2013 6:23 PM
DSL Connection
Link Information
Uptime: 1 day, 2:44:58
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1,063 / 6,331
Data Transferred (Sent/Received) [MB/GB]: 50.59 / 0.97
Output Power (Up/Down) [dBm]: 12.8 / 0.0
Line Attenuation (Up/Down) [dB]: 27.5 / 49.0
SN Margin (Up/Down) [dB]: 5.9 / 6.6
Loss of Link (Remote): -
Error Seconds (Local/Remote): 1,749 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 118 / 2,558
HEC Errors (Up/Down): 58 / 7,345
My IP profile was 5.69meg but upto 7.25 available if I remember.
29-09-2013 6:24 PM
29-09-2013 6:29 PM
29-09-2013 7:05 PM
A speedtest normally maxes out at 5.04meg. I used to easily get 6.3meg.
29-09-2013 8:11 PM
Quote from: Damian78 5.4meg.
That is fine for your current sync speed. You won't be able to get any faster until you sync faster.
I would suggest that you restart your router tomorrow at mid-day and then post your stats then.
If there is no difference, then the only answer is to get the SNRM reduced to 3dB (I suspect is has increased from 3dB to 6dB), which the Digital Care Team (Plusnet staff) can help you out with tomorrow. But please try that first to see if that makes any difference.
02-10-2013 4:58 PM
DSL Connection
Link Information
Uptime: 0 days, 0:02:27
Bandwidth (Up/Down) [kbps/kbps]: 1,087 / 6,592
Data Transferred (Sent/Received) [kB/kB]: 156.21 / 79.75
Line Attenuation (Up/Down) [dB]: 27.4 / 49.0
SN Margin (Up/Down) [dB]: 5.8 / 5.9
Error Seconds (Local/Remote): 1 / 0
CRC Errors (Up/Down): 0 / 1
HEC Errors (Up/Down): 0 / 5
02-10-2013 6:28 PM
I think what has happened is that your target SNRM has increased to 6dB from 3dB. We need this to be put back to 3dB but we need the Plusnet staff to do that. I expect they'll be a long to help soon.
03-10-2013 12:58 PM
I'll place the SNR reset to 3dB and see how that goes, if your line cannot handle this it will move back to at least 6dB.
03-10-2013 5:34 PM
DSL Connection
Link Information
Uptime: 0 days, 4:07:29
Bandwidth (Up/Down) [kbps/kbps]: 1,075 / 7,555
Data Transferred (Sent/Received) [MB/GB]: 60.59 / 1.32
Output Power (Up/Down) [dBm]: 12.6 / 0.0
SN Margin (Up/Down) [dB]: 5.5 / 2.8
Loss of Framing (Local/Remote): 9 / 0
Loss of Signal (Local/Remote): 1 / 0
Error Seconds (Local/Remote): 5,517 / 0
CRC Errors (Up/Down): 67 / 24,929
HEC Errors (Up/Down): 71 / 5,791
03-10-2013 6:43 PM
05-10-2013 3:46 PM
Just checked and got this 😞
DSL Connection
Link Information
Uptime: 0 days, 2:46:02
Bandwidth (Up/Down) [kbps/kbps]: 1,024 / 7,438
Data Transferred (Sent/Received) [MB/GB]: 154.99 / 2.24
SN Margin (Up/Down) [dB]: 5.8 / 2.8
Loss of Framing (Local/Remote): 17 / 0
Loss of Signal (Local/Remote): 2 / 0
Error Seconds (Local/Remote): 61,645 / 0
FEC Errors (Up/Down): 4,561,582 / 38,353,041
CRC Errors (Up/Down): 438,750 / 590,298
HEC Errors (Up/Down): 941,672 / 323,137
05-10-2013 4:03 PM
Never in the history of me having ADSL have I ever had so many problems 😞
05-10-2013 4:37 PM
Got these stats now. Ping has increased from 30ms to 49ms on Speedtest though :-S
DSL Connection
Link Information
Uptime: 0 days, 0:06:21
Bandwidth (Up/Down) [kbps/kbps]: 1,060 / 7,342
Data Transferred (Sent/Received) [MB/MB]: 6.89 / 37.69
Error Seconds (Local/Remote): 3 / 0
FEC Errors (Up/Down): 0 / 53,476
CRC Errors (Up/Down): 0 / 4
