IP Profile reset please
uren1980
Currently getting 300-500kbits per second due to Plusnet profile reset. The problem had been sorted so can I have the profile put back up please.
BT speedtest (bt_test_user version)
Download speedachieved during the test was - 1845 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :2720 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2000 Kbps
Current Plusnet transfer speed:
Postcode:
    GLXX XXX
Phone exchange:
    CHELTENHAM
Estimated line speed:
    4.0 - Checked on 2009-09-14 21:28:58
Current line speed:
    500
Fixes: 167
Re:IP Profile reset please
Yep, I'll go pick this up for you now. Give it 5 minutes and you should see the profile realign.
 Chris Parr
 Plusnet Staff
uren1980
Re: IP Profile reset please
Thanks mate, I've gone from 350-500k (god that was horrid) back to the usual 2mbit and my girlfriend says you are a nice kind generous person.
I did leave a ticket about this but I will close this myself.
