IP Profile problem
- IP Profile problem
IP Profile problem
02-06-2015 8:40 AM
I've recently had problems on my connection which resulted in my ip profile being set down to 0.14 Mbps. The phone line has now been fixed (yesterday) and all the line noise has gone and I've had a rock solid connection since then at 7.168 Mbps - over 20 hours in all. However, the IP profile has not reset at all and according to the adaptive max logic guidance this should have reset in around four hours. I can only conclude that the ip profile has got stuck and I'd like to know how I can get it unstuck. This is really frustrating as there is absolutely no good reason why my connection should be capped at 0.14. If anyone can suggest what I can do to kick it back into life I would be grateful.
Message 1 of 4
(647 Views)
3 REPLIES 3
Re: IP Profile problem
02-06-2015 11:04 AM
Message 2 of 4
(472 Views)
02-06-2015 11:14 AM
Thanks Matthew. That did the trick! I can now get back to work (I work from home so haven't really been earning my keep recently :(). I'm so happy that we PN customers have such a great resource as this forum, and appreciate all the help you guys (and gals) provide.
Message 3 of 4
(472 Views)
02-06-2015 11:36 AM
Message 4 of 4
(472 Views)
