IP Profile not setup correctly
- Re: IP Profile not setup correctly
08-09-2012 8:11 AM
I was meant to be upgraded to plusnet fiber 80Mb but there is very clear problems why i can only download at 40Mb.
As you can see by the screen shots bellow i need my IP profile reset to 76Mb NOT 48Mb !
Also if not sorted very soon i will leave my contract free off charge !
http://www.pcadvisor.co.uk/news/internet/3233346/brits-can-get-out-of-broadband-contracts-with-no-pe...
08-09-2012 2:30 PM
How far are you from the cabinet?
The only thing I can see wrong is that your current line speed on the portal should be 40, not 48.
08-09-2012 4:40 PM
Also if you have an look at the BT speed tester it shows 40Mb download and that i am NOT on an 80Mb broadband package.
As most people know , you download speed will never go over your IP profile.
08-09-2012 5:09 PM
Also you might want to remove your telephone number from the picture in the first post
08-09-2012 5:12 PM
Witch is what i am trying to explain to plusnet on the phone
Thanks for telling me about phone number , removed from image now
08-09-2012 5:19 PM
The only argument you seem to have is that you are close enough to the cab to get higher speeds but you don't know the quality or length of cable between you and the cab.
When BT first set up the fibre what speeds were you getting
Also from the BT speedtest what is the upstream IP profile
08-09-2012 5:23 PM
08-09-2012 5:39 PM
When you said upgraded I assumed that you meant from the 40Mb package not from ordinary ADSL hence my question
08-09-2012 5:44 PM
But seams they have not reset my ip profile and just left on the 40Mb one
08-09-2012 5:51 PM
Your IP profile is higher than what is possible on a 40Mb connection, so it has increased. Furthermore, the IP profile is set automatically based upon how fast your modem syncs to the equipment in the cabinet. It is highly unlikely that you'll get anywhere near 76Mbps at that distance from the cabinet.
Interesting that the Plusnet profile is set to 48Mbps. Perhaps you have previously synced slightly higher that you are now (not massively higher) and that either you have resynced at a different time of day to that higher rate, or the DLM has determined that your connection was not stable enough at that rate. In any case, I believe that you will be told that everything is working as expected (be that from Plusnet, BT, or another ISP if you leave).
08-09-2012 6:13 PM
"Lee, I have checked the details and see that this is an FTTC circuit and only an engineer can perform the profile reset on this. Please contact your service provider"
So really all Plusnet did was change the IP profile only on there system because can only be done by an engineer. If plusnet would of just known / said this to me then would of saved
me an lot of time. From now on i think if plus net no help any more i will just talk to BT Wholesale directly till Plusnet give there staff more training.
08-09-2012 11:07 PM
08-09-2012 11:26 PM
Quote from: jelv What on earth makes you think your profile should be 76Mb?
Your current IP Profile proves beyond any shadow of doubt that you are on the 80 Mb product as that speed is impossible on the 40Mb product.
What was the speed estimate given when you ordered fibre?
10-09-2012 1:58 PM
I have checked your connection and profile. You are currently on our 80MB product, your profile is set 48MB/s which appears to be the correct profile on your line.
As I see you have raised a fault and our faults team are investigating this, I will leave it with them and await their results.
Please let me know if you need any further assistance with this.
Chris
13-09-2012 2:20 AM
