IP Profile differences
- IP Profile differences
Re: IP Profile differences
27-09-2013 11:05 PM
Can one not complain to Ofcom about the appalling attitude to Openreach and their ISP's customers. In private enterprise they would be bust.
Lost two days pay now, and no compensation, just to get what I paid for.
Disgusting !
30-09-2013 10:12 AM
Anybody able to tell me when this might get sorted
30-09-2013 10:35 AM
30-09-2013 2:25 PM
Have a read of http://www.moneysavingexpert.com/shopping/delivery-rights
30-09-2013 5:06 PM
PN are being very helpful at saying there is no response from BTOR, can nothing be done to get this fault resolved
01-10-2013 10:34 AM
02-10-2013 2:37 PM
BTOR now left and say to refer fault back to you and you should have checked profile before calling him out.
I'm getting very brassed off now. Why am I on wrong profile ?????????
02-10-2013 7:32 PM
If you are on the 40/10 profile you should get up to just short of that (around 37) - if you are not getting near that and you still get the same low speed using a direct pppoe wired connection to the modem it's a BTOR issue.
02-10-2013 9:39 PM
That's a really useless answer
Fault raised 20 September
various blame attached
BTOR appointment booked 27 Sep
BTOR never showed (blamed on Plus Net)
New Appointment Today.
BTOR test speed at NTE 24mps
BTOR made line check quoted as 100%
BTOR claimed distance to Cab 700 yards (old money)
TOR claim speed restriction due to Plus Net
BTOR left claiming wasted visit may be chargeable
I the CUSTOMER after 3 last half days off work and 13 days after install exactly where I was
WHEN WILL YOU SORT OR DO I HAVE TO LEAVE PLUS NET FOR CONTRACT FAILURE
02-10-2013 11:13 PM
The 40 of 40/10 is just a cap on the download speed, it doesn't change anything else. If you a syncing at 25 on 40/10, when your service is changed to 80/20 you will still sync at around 25*. If you were syncing at around the maximum on 40/10 then changing to 80/20 would see an increase in sync speed. That's why I was saying that what the engineer said was rubbish.
Plusnet will have to push the fault back to them which will probably mean another engineer to be booked.
03-10-2013 8:35 AM
I was saying the process is getting somewhat protracted, I have to take time off every visit
TH BT engineer said the connection to my socket was fine, it was a restriction that is stopping the speed
Tony
03-10-2013 10:04 AM
03-10-2013 11:27 AM
03-10-2013 4:01 PM
It appears that the engineer is still investigating your fault and we are waiting for his engineer notes.
03-10-2013 6:09 PM
Thanks, its been on those sort of numbers since install. At that time it seemed part of the backend, thought I was still on ADSL2+ and I suspect that's why the IP profile is at the top of the ADSL2+ range.
Tony
