IP Profile changed
- IP Profile changed
IP Profile changed
18-11-2011 12:19 PM
As ive said first 3months were great now seems my service is being reduced. May I ask why? Have done all steps to ensure hard line connection, checked filters, line, restarted my pc and router, even done the test socket and still the same. I know its not my end as I dont set my IP profile and nothing has changed in my setup or phone line since I joined.
Re: IP Profile changed
18-11-2011 12:24 PM
DSL Type: G.992.1 annex A
Channel mode: Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,180 / 6,944
Bandwidth (Up/Down) [kbps/kbps]: 448 / 6,848
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 9.92
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 5.5 / 15.0
SN Margin (Up/Down) [dB]: 27.0 / 15.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
quite a high SN Margin compared to when was with BT, its almost double what they gave me.
18-11-2011 1:32 PM
The SNR is what will be making things slower. The thing is, there must be some reason for this increase. How is your kit set up? Are you using any extension sockets/cables before your router? Are you using the test socket?
Jojo
18-11-2011 2:18 PM
Old Router logs:
Jul 21 00:29:05 syslog: Clear IP addresses. Connection DOWN.
Jul 21 00:35:37 syslog: Clear IP addresses. Connection DOWN.
Jul 21 00:42:09 syslog: Clear IP addresses. Connection DOWN.
Jul 22 17:35:58 syslog: Clear IP addresses. Connection DOWN.
Jul 22 17:42:30 syslog: Clear IP addresses. Connection DOWN.
Jul 22 19:57:03 syslog: Clear IP addresses. Connection DOWN.
Jul 23 13:14:13 syslog: Clear IP addresses. Connection DOWN.
Jul 23 15:28:46 syslog: Clear IP addresses. Connection DOWN.
Jul 23 15:35:18 syslog: Clear IP addresses. Connection DOWN.
Jul 23 19:57:52 syslog: Clear IP addresses. Connection DOWN.
Jul 23 20:04:24 syslog: Clear IP addresses. Connection DOWN.
Jul 23 22:18:57 syslog: Clear IP addresses. Connection DOWN.
Jul 23 22:25:29 syslog: Clear IP addresses. Connection DOWN.
Jul 24 16:01:46 syslog: Clear IP addresses. Connection DOWN.
Jul 24 22:32:20 syslog: Clear IP addresses. Connection DOWN.
Jul 25 14:33:04 kernel: Line 0: ADSL link down
Jul 25 14:33:06 syslog: Clear IP addresses. Connection DOWN.
Jul 25 14:33:06 syslog: Clear IP addresses. PPP connection DOWN.
Jul 25 14:33:06 kernel: Line 0: xDSL G.994 training
Jul 25 14:33:11 kernel: Line 0: ADSL G.992 started
Jul 25 14:33:13 kernel: Line 0: ADSL G.992 channel analysis
Jul 25 14:33:18 kernel: Line 0: ADSL link up, fast, us=448, ds=8128
Jul 25 14:33:27 syslog: PPP LCP UP.
Jul 25 14:33:27 syslog: Received valid IP address from server. Connection UP.
Old Router stats:
Tue 19 Jul 2011 17:46:25 Rx-Noise=9.1 Tx-Noise=22.0 Rx-Sync=8128
I dont know if any of that is useful to you or not but I think may help with noise example.
21-11-2011 4:19 PM
Uptime: 3 days, 4:07:40
Data Transferred (Sent/Received) [kB/GB]: 0.00 / 1.00
SN Margin (Up/Down) [dB]: 27.0 / 15.0
FEC Errors (Up/Down): 18 / 1,064
CRC Errors (Up/Down): 2 / 0
21-11-2011 4:35 PM
Are you still in the test socket or did you put it back?
Jojo
21-11-2011 4:49 PM
Uptime: 0 days, 0:07:33
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,180 / 6,880
Bandwidth (Up/Down) [kbps/kbps]: 448 / 6,784
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 5.82
Output Power (Up/Down) [dBm]: 12.5 / 19.5
SN Margin (Up/Down) [dB]: 28.0 / 15.5
Loss of Signal (Local/Remote): 4 / 0
Error Seconds (Local/Remote): 3 / 0
22-11-2011 10:56 AM
Uptime: 0 days, 18:07:27
Data Transferred (Sent/Received) [kB/GB]: 0.00 / 2.31
FEC Errors (Up/Down): 1 / 157
22-11-2011 11:04 AM
The SNR is quite high and I want to reset it. I needed you to be in the test socket because that would rule out any possibility of it being the internal wiring. I'll reset the SNR but leave it in the test socket as long as you can so we can see how it performs.
Jojo
22-11-2011 11:07 AM
22-11-2011 12:04 PM
The reset has brought the sync back up to 8128 and your profile to 7150. I have matched our profile to this so you should see the difference in the next 15 minutes.
Jojo
22-11-2011 12:23 PM
22-11-2011 2:27 PM
Not traffic management but Dynamic Line Management (DLM) looks to me like it was pushing your SNR up due to noise which will bring your sync rate, and consequently your profile, down. If you can leave it in the test socket for as long as possible so that we can see how it performs that would be good.
Jojo
