IP Profile bump?
- Re: IP Profile bump?
IP Profile bump?
20-12-2011 11:49 AM
Quote Estimated line speed:
8Mb (Accurate to within +/- 1Mbit) - Checked on 2011-12-13 07:45:29
Current line speed:
2 Mb
Quote Download speed achieved during the test was - 1707 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :4320 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2000 Kbps
I was able to reach download speeds of up to 750kb/s but now it has dropped to 250kb/s.
Thanks.
20-12-2011 12:05 PM
Your profile on BT and PN are both the same at 2000. Where are you seeing these speeds? Are you using any extension cables/sockets? Could you plug into the test socket so I can re-check your line?
Jojo
20-12-2011 4:38 PM
My brother disconnected the current router we're using now and replaced it with the original Thomson then switched them back. A day after doing that I noticed a speed drop from 700 kb/s to 250 kb/s max.
We're on wireless so we don't have any extension cables plugged in.. we also don't have a test socket.
dick:quote
20-12-2011 5:01 PM
Ok, make sure you don't have anything plugged in any extensions and run a BT speed test using a wired connection to the router. Once you've done that if you could post the results here we can look towards the next step.
Jojo
20-12-2011 5:55 PM
Download speed achieved during the test was - 1728 Kbps
These results are from a wired connection to the router.
20-12-2011 6:16 PM
(If you leave everything as it is there's a chance it might correct itself overnight, but if not I'm sure the Digicare team will pick it up again for you in the morning.)
21-12-2011 8:35 AM
It does seem to be stuck. I'll reset the line and see if that kicks it into action. I'll keep an eye on it and let you know later.
Jojo
21-12-2011 12:08 PM
21-12-2011 1:25 PM
No it's not. I've just ran a check and you#re only getting a sync of 160k. Can you reboot the router for me please?
Jojo
21-12-2011 2:21 PM
I have just reset the router as you asked. Hopefully the speed should increase?
21-12-2011 3:54 PM
It's not looking much better. I've just tried ringing you to discuss.
Jojo
21-12-2011 4:09 PM
21-12-2011 4:41 PM
Thanks for your time on the phone. Looks like the change of router has sorted it. We just need to wait for the BT profile to lift now.
Jojo
21-12-2011 5:04 PM
22-12-2011 7:48 AM
Quote Download speed achieved during the test was - 107 Kbps
For your connection, the acceptable range of speeds is 50-250 Kbps.
Your DSL Connection Rate :3904 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 135 Kbps
Could it be stuck?
