IP Profile and DL Speed
- IP Profile and DL Speed
24-11-2010 1:02 PM
Have recently contacted support about this and the guy I spoke to did try to help. But, not sure anything's happening?
My router stats:
Uptime: 0 days, 2:39:13
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,140 / 15,352
Bandwidth (Up/Down) [kbps/kbps]: 444 / 13,827
Data Transferred (Sent/Received) [MB/MB]: 20.97 / 89.94
Output Power (Up/Down) [dBm]: 12.0 / 20.5
Line Attenuation (Up/Down) [dB]: 17.5 / 30.0
SN Margin (Up/Down) [dB]: 26.0 / 5.0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 1,427 / 0
FEC Errors (Up/Down): 21,888 / 63,255,607
CRC Errors (Up/Down): 2,594 / 70,309
HEC Errors (Up/Down): 1,818,558,472 / 507,075
Thing is, I'm only getting around a 5.3 Mb/s DL speed. I'm a bit lost with all of this. Just not sure why I cannot get any more out of my connection.
What I would like is to get any restrictions lifted or my IP profile increased, if possible. Any help would be appreciated. Oh, tried the Maximum adsl speed calculator over at Kitz and got:
Approx Line Length: 2.2 km
adsl2+ (21CN): 15264
IP Profile: 13000
My router stats:
IP Profile: 13000
Message 1 of 9
(1,074 Views)
8 REPLIES 8
Re: IP Profile and DL Speed
24-11-2010 2:38 PM
Any support staff around? What I'd really like is for my IP profile to be reset, somehow. My IP profile is set at 5500 Kbps, but when I check via the PN site, it reports:
Estimated line speed:
7 - Checked on 2010-10-25 16:16:10
Current line speed:
10000
Help needed please, thanks.
Current line speed:
10000
Message 2 of 9
(636 Views)
24-11-2010 2:43 PM
Are you connected to your router wired or wireless?
Message 3 of 9
(636 Views)
24-11-2010 3:05 PM
Wired connection. Thanks for replying Jelv.
Message 4 of 9
(636 Views)
24-11-2010 6:08 PM
HI Stogi,
Just ran a line check and the BT profile is 12000 so I've just matched the PN one to it.
Jojo
Jojo
Message 5 of 9
(636 Views)
24-11-2010 6:24 PM
Hey Joanne
Many thanks. I'll give it a few days... Oh, do I need to reset my router, in the morning?
Message 6 of 9
(636 Views)
24-11-2010 6:27 PM
Hi Stogi,
Yes, If you're going to reboot your router it's always best to do it in daylight hours.
Jojo
Jojo
Message 7 of 9
(636 Views)
24-11-2010 6:30 PM
Just ran a speed test and got back 10708 kbps
Yes, it'll probably drop a little once stable, but hey, big thanks Joanne.
Message 8 of 9
(636 Views)
24-11-2010 6:37 PM
Hi Stogi,
I don't see why it should drop, unless you lose sync and it picks up a bad rate when it reconnects, otherwise you may even get more than that.
Jojo
Jojo
Message 9 of 9
(636 Views)
