IP Profile Question
chewie
IP Profile Question
Hi, hopefully someone can answer this for me.  I have raised a support ticket to increase my line speed to match my IP profile (my line speed is set to 4.2Mbps and my IP profile is currently 4.99Mbps).
The response I received was that my current sync speed is 4.8Mbps and because the ADSL service can only utilise 88% of the sync speed to keep the service stable then my line speed will have to remain capped at 4.2Mbps.
Would someone be able to explain this to me please?  I've always had to request for my line speed to be increased previously as it never seems to match my IP profile automatically.  As far as I'm aware the line speed has always been set the same as my IP profile so I'm a bit confused as to why it now has to be set lower than this.  If someone could clear this up for me I'd appreciate it.
Thanks.
Fixes: 62
Re: IP Profile Question
On ADSL the BT IP profile is always set at 88.2% of the sync speed as reported by your router and the Plusnet profile is the same but rounded down to the nearest 0.1Mbps
What is the actual sync speed as reported by your router - this gives it for a Plusnet router http://192.168.1.254/cgi/b/dsl/dt/?ce=1&be=0&l0=1&l1=0
However when you say line speed are you referring to the Current Line Speed as reported here https://portal.plus.net/my.html?action=data_transfer_speed then you are correct it will be the same as the BT IP profile rounded down to the nearest 0.1Mbps as it isn't the line speed at all it is the Plusnet profile - it is just their stupid terminology
chewie
Ok thanks for that, so if my BT profile is 4.99Mbps then the Plusnet profile should be 0.1Mbps below this and not set to 4.2Mbps, is that correct?
I don't have a Plusnet router I have an Asus DSL-N55U.  I've logged in as admin to try and find the current synch speed but not sure where I'd find this.  It lists Data Rate Down in the log, is that the same thing?  This is currently 5382mbps.
Fixes: 62
That is correct but if the sync rate is 5382kbps then the IP profile will be 4,740kbps
Perhaps someone who has this router can comment
Either way the staff on here should pick this up tomorrow although I wonder if the agent you spoke to was looking at the right line as he was seeing a sync speed of 4.8Mbps
chewie
Many thanks for your advice on this.  I've checked this morning and my BT IP profile is still set to 4.99Mbps so hopefully someone will adjust the Plusnet profile to match.
Acassim
Hi Chewie,
I've taken a look into this for you and can see that the sync speed is indeed higher than the profile on our side however DLM is in effect on the line at present which is holding the speed down around the 4.2mbps mark. There doesn't appear to be anything evident by way of a fault on the line from testing however the graph below shows some serious drops in connection around the 27th and 28th of October which does seem to tie in with the application of the DLM.
<img src="http://community.plus.net/visualradius/generated/image14151810142213.png"/>
After taking a look over your previous faults I can see that an SNR reset was placed to raise the targets and regain stability of the connection which seemed to fix the problem however this didn't seem to address DLM which was restricting the speeds. Given this, I'm going to attempt to reset this for you again and hopefully this should release the DLM and bring the speed back up to match the BT profile.
This will normally complete within the next 4 hours however it can take up to 24 hours for the reset to take effect in some cases so if you can let us know how the connection is looking this time tomorrow, hopefully we should see the actual speed increase.
chewie
Hi, thanks for this.  I've just checked again and my Plusnet profile has now increased to 4.7Mbps however, it still doesn't match my BT IP profile which is still at 4.99Mbps.
Fixes: 5
Hi chewie,
I've manually updated the profile for you to 4900k (the most suitable profile we have for you).
You should automatically lose and regain your connection within the next half hour or so. At this point you'll see the new throughput.
Tony
 Tony T
chewie
Great, just noticed it increase.  Thanks for doing this so quickly Tony  Smiley
chewie
This maybe a stupid question but can anyone tell me how I would find out if I'm on ADSL 2 or not?  My exchange is 21cn enabled but I would have thought I would get faster speeds if on ADSL2 however the max speed for my line according to the BT speed check is 7.15Mbps.
Fixes: 62
Given your previous posts - have you just moved house
If so what is the full result from a BT speedtest Further diagnostics
chewie
Yes, I've recently moved into a new house where the speed is unfortunately considerably slower than at my previous address  Sad
Attached is the BT further diagnostics report
Fixes: 62
Something is adrift
I always thought that you only got an upstream IP profile on 21CN but the Max achievable speed would seem to indicate that you are on 20CN even though the downstream IP profile is for 21CN
This will need staff input but, if you are on 21CN then you need the upstream uncapping
Your other thread  is related to this so I have merged them
Acassim
Hi chewie,
I've now placed a modify order to uncap your upload speeds so this should be complete by Monday, Apologies for any confusion that caused, it should have been done at the point of the house move but appears to have been overlooked.
Acassim
Just as a follow on from this, I've run through a few faults tests based on the questioning that OldJim raised so we can look at the profile you having showing on the dslchecker results.
This returned a few interesting results as it seems the connection has been dropping quite severely today and testing also flagged a possible profile mismatch. While I haven't ever seen the possible 20cn profile showing in the dslchecker being flagged as a profile mismatch I've decided to raise a fault through to the supplier to investigate both issues further.
There is now a fault ticket on your account which will be updated once we have some more information back from the supplier following their testing.
