IP Profile - Plusnet showing customer cervice flaws
- IP Profile - Plusnet showing customer cervice flaw...
19-04-2013 4:50 AM
I raised a ticket with Plusnet and have just got the run-around. I'm sure this was done quickly before. All I'm getting now is cut-and-paste irrelevant responses or ... silence.
What has changed with Plusnet? It looks like you outsourced your call centre but why don't your agents give a damn any more?
Re: IP Profile - Plusnet showing customer cervice flaws
19-04-2013 6:55 AM
19-04-2013 8:48 AM
It will look something like this:
Quote Download speedachieved during the test was - 6.21 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :7.81 Mbps(DOWN-STREAM), 0.83 Mbps(UP-STREAM)
IP Profile for your line is - 6.5 Mbps
19-04-2013 9:37 AM
Our faults team are currently testing your line, it may be that we need to place a SNR reset on your line to resolve this but we need to make sure this is this right course of action first.
We'll update your fault ticket as soon as testing has completed.
19-04-2013 8:55 PM
Why is this so difficult?
I don't want my line testing. It is delivering 0.25 on a 0.25 IP profile. Plusnet sent me a load of stuff showing it would sync at some number above 3M. Why do you want to test it again? Where have the people gone that used to just read your text and fix things? Why do I get this computer/goon generated template stuff?
Ah... the good old days before all this yorkshire accent nonsense...
19-04-2013 9:09 PM
For your connection, the acceptable range of speeds is 0.1 Mbps-0.25 Mbps.
IP Profile for your line is - 0.25 Mbps
Upload speed achieved during the test was - 0.36Mbps
Upstream Rate IP profile on your line is - 0.45 Mbps
Yesterday, Plus got a Fault Threshold Rate of 3.63mbps
20-04-2013 9:56 AM
Now that the phone fault is fixed Plusnet will want to see that the line is stable with few errors so will be looking at the error rates. They also need to see how long it is managing to hold a connection (I hope you've been leaving it on permanently with no reboots).
Could you post the full router stats please. If you are using a Plusnet supplied TG582n you get them from here: http://192.168.1.254/cgi/b/dsl/dt/?be=0&l0=2&l1=0 (it will require you to enter the user name and password from the card supplied with the router).
It will look like this:
Quote Uptime: 1 day, 1:15:27
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 832 / 7,808
Data Transferred (Sent/Received) [MB/MB]: 115.12 / 431.91
Output Power (Up/Down) [dBm]: 12.6 / 19.8
Line Attenuation (Up/Down) [dB]: 13.5 / 21.0
SN Margin (Up/Down) [dB]: 15.0 / 6.5
Chipset Vendor ID (Local/Remote): BDCM / ????
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 0 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 0 / -
FEC Errors (Up/Down): 552 / 404
CRC Errors (Up/Down): 374 / 0
HEC Errors (Up/Down): - / 0
22-04-2013 1:03 AM
However the bad new is I'm still getting 0o.25 actual speed.
I re-booted the modem but that has made no difference.
What do I have to do now? And does anybody know how I raise a a ticket - it takes me 15 minutes to find that normally, and then you often have to answer a load of irrelevant questions on the way./
22-04-2013 1:05 AM
22-04-2013 8:03 AM
22-04-2013 6:41 PM
I've got two tickets running and I might as well be on the planet Zog.
If I ring up, I'm told I'll have to wait for 20 Minutes.
Is there nothing we can do, given the Plusnet Call Centre simply doesn't work any more?
Or are they on a fortnight's holiday and will be back any week soon?
23-04-2013 9:55 AM
I've just corrected the speed profile on your account. There's clearly still a problem with disconnections but one of my colleagues on the faults team should be looking into that now.
Adam
23-04-2013 9:55 PM
adie:orange CSA name removed as per link:rules
24-04-2013 12:16 AM
