IP Profile Hasn't Been Updated
- IP Profile Hasn't Been Updated
25-07-2009 7:41 AM
Hello,
Following a series of disconnections during a thunderstorm, my connection has now been stable for more than a week yet my IP profile is still set at 500kps.
Am I just being impatient or should I raise this issue with BT?
Thanks in advance.
Thanks in advance.
Message 1 of 8
(1,220 Views)
7 REPLIES 7
Re: IP Profile Hasn't Been Updated
25-07-2009 7:46 AM
Hi, welcome to the forums
What does the BT speedtester give your profile as? Find out here
Message 2 of 8
(653 Views)
25-07-2009 7:50 AM
Hi adiewoo, thanks for the quick reply.
These are the results from about an hour ago:
Your DSL connection rate: 6496 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 500 kbps
Actual IP throughput achieved during the test was - 389 kbps
Message 3 of 8
(653 Views)
25-07-2009 7:59 AM
You profile should raise after 3 days connection after your speed went up - possibly much quicker given the difference between your profile and connection speed.
Couple of possibilities are that you have a stuck profile a BT's end or you've had another low synch event in the mean time.
Someone from PN maybe able to tell you this, but not sure if anyone will be around as it's the weekend.
You could try raising a fault at http://faults.plus.net/
Message 4 of 8
(653 Views)
25-07-2009 8:00 AM
You could try using RouterStats if your router supports it monitor what is going on as well.
Message 5 of 8
(653 Views)
25-07-2009 8:43 AM
if you phone up the CSC and go to the talk to option, talk nicely and ask what the radius links show, that is the disconnect log
Plusnet Customer Support (geographic number for sheffield CC.) 0114-296-5198*
*May be chargeable depending upon phone package or Broadband Faults Helpline: 0845 140 0080 - free if you are on PN Homephone
Message 6 of 8
(653 Views)
25-07-2009 4:00 PM
I'm not sure if it was running Plusnet's fault checker but my connection's finally back at full speed.
Thanks for the help!
Message 7 of 8
(653 Views)
25-07-2009 5:03 PM
No worries, glad it's sorted.
Message 8 of 8
(653 Views)
