IP Profile - 88.2% method
- IP Profile - 88.2% method
Re: IP Profile - 88.2% method
23-09-2011 3:48 PM
23-09-2011 3:48 PM
Now if, on receipt of a delta report, the profile was updated on an individual basis that wouldn't be a problem but as far as I am aware it is done by a script being run which checks all the accounts and updates where necessary. If I am correct then there is clearly a practical limit to how often you run the script
23-09-2011 3:50 PM
23-09-2011 4:00 PM
[quote=Joanne Pilson]Once the new system is in place, if these reports are any more frequent we'll look at how we will deal with them.
23-09-2011 4:12 PM
If the delta reports are received at present on an individual line basis and not as a block feed from BT then the reports won't be any more frequent just quicker after a speed change (unless there is a line problem causing multiple resyncs.) so if you can increase the frequency why not start doing it now
Of course if you receive, and will continue to receive, bulk updates from BT then the point is moot
23-09-2011 4:17 PM
23-09-2011 4:23 PM
ID Net lowest package - £15.31 per month 2GB peak allowance 10GB off peak allowance
Does that answer the question.
Secondly my line is normally very stable so it doesn't affect me personally to any great extent
23-09-2011 4:26 PM
23-09-2011 4:27 PM
23-09-2011 4:29 PM
23-09-2011 4:30 PM
26-09-2011 10:05 AM
My BT profile seems to have been changed to an 88.2% one after a resynch on the 23rd. Its now at 11515 but my PlusNet one seems to be stuck at 10000.
26-09-2011 10:23 AM
Your DSL Connection Rate :6565 Kbps(DOWN-STREAM), 803 Kbps(UP-STREAM)
IP Profile for your line is - 5792 Kbps
PN is:
5500
26-09-2011 10:29 AM
@Dvorak, I've moved yours to 6000
Just bear in mind though that these may drop down again with the next delta reports, as we're still getting the ones in 500/1000 increments below what your profile is reporting.
Jojo
26-09-2011 10:34 AM
