IP Profile - 88.2% method
- IP Profile - 88.2% method
Re: IP Profile - 88.2% method
13-10-2011 5:18 PM
Quote from: Oldjim The speed tester doesn't work on an average over the duration of the test
As Jim said most don't use the average they report the peak speed and often use multiple threads.
One test that does give reliable results (average speed based on the time to download the whole test file as a single thread) is http://www.thinkbroadband.com/speedtest.html
13-10-2011 7:50 PM
14-10-2011 12:33 PM
Edit Sorry, should have posted this in the 88.2% thread but don't know how to move it.
14-10-2011 1:54 PM
14-10-2011 2:05 PM
At the current moment:
Sync rate - 13759K
BT Profile - 12135K
Plusnet Profile - 12000K
From December could be changing to this:
Sync rate - 13759K
BT Profile - 12135K
Plusnet Profile - 12135K or 12200K or 13000K
21-10-2011 12:24 PM
21-10-2011 2:36 PM
Can you tell me your sync rate, BT IP profile and Plusnet profile?
Jojo
21-10-2011 2:51 PM
Can any of you that have a non-rounded profile tell me what your figures are for..
1. Sync
2. BT IP Profile
3. Plusnet Profile (I can always check this if you're not sure)
That would be great thanks,
Jojo
21-10-2011 2:59 PM
With my long ago memories of working with numbers in mind, I ask a question, that I hope you will not consider condescending.
Are you positive you have not made a calculation error, used wrong data or calculation. or misread the results? It's so easy to do.
Can you recall what the synch was?
21-10-2011 3:03 PM
could you possibly give me your figures which i asked for above please?
thanks,
Jojo
21-10-2011 3:04 PM
Quote from: Joanne Can any of you that have a non-rounded profile tell me what your figures are for..
1. Sync
16.71 Mbps (17115)
Quote 2. BT IP Profile
15100
Quote 3. Plusnet Profile (I can always check this if you're not sure)
15Mb
21-10-2011 3:07 PM
BT Profile 6101
Plusnet Profile 6000
21-10-2011 3:15 PM
1. Sync 9292
2. BT IP Profile 8198
3. Plusnet Profile 6500
(BTW sync has SNR 3.5 db in day. Late evening drop and resync @6db cause speed drop conforming with PN IP Profile)
21-10-2011 3:42 PM
BT Profile 4236 Kbps
Plusnet Profile 3500 Kbps
(That's ADSL2+ folks!)
21-10-2011 3:53 PM
