IP Profile 250kbps!
- IP Profile 250kbps!
IP Profile 250kbps!
15-07-2009 1:01 PM
The last few days connection speed has been absolutely crawling along even tho the line rate is between 2-3.7mb, my IP Profile seems to be stuck at 250kbps and my god it shows.
I thought this would increase again after a couple of days but doesnt seem to be moving at all. Is this a BT Issue or can PN change it?
Should I try turning off and on the router or will this just set it back again?
Any help will be much appreciated.
P.S I went through a set of tests yesterday and the results (and extra info from me) were sent to support but I havent heard anything back.
BT TEST RESULTS TODAY-
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 3936 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 250 kbps
Actual IP throughput achieved during the test was - 144 kbps
Re: IP Profile 250kbps!
15-07-2009 1:12 PM
Do nothing.
If you hold that sync speed, the IP Profile should increase within 24 hours. It'll be a good idea to checfk that you're not getting disconnections though and that's likely to have caused the drop in the first place.
15-07-2009 1:20 PM
Thought it would have been increased by now as its been stable for around 3 days.
15-07-2009 2:13 PM
16-07-2009 7:32 AM
Actual IP throughput achieved during the test was - 194 kbps
Using a speed test it goes straight to 200kbps and doesnt dip during the test..which suggests its being held back significantly. Its becoming a nightmare at these speeds, and I have to say the customer service from PN is really poor. I havent even had a reply to my information sent 2 days ago
16-07-2009 9:55 AM
If your router is prone to dropping during Thunderstorms it would be best if you turned it off. You sync at a low speed and down goes your IP Profile again - and you start the three day count to get it back up again.
There is supposed to be some BT blip logic which should ignore a one off low speed sync (e.g. a thunderstorm), but it obviously hasn't worked for you.
16-07-2009 10:04 AM
![Wink Wink](/html/@ED8EAB3707DE077FFF94EEBAB958E3C6/images/emoticons/wink.gif)
Quote With effect from Aug 2007, BT will introduce "Adaptive Max Logic" which will replace both the 3 day system and Blip logic. This should be of benefit to those who have suffered from an unusually low sync, although smaller increases will take a bit longer.
Quote ~ What is "Adaptive Max Logic"?
Decreases in sync speed will still reflect in the IP profile within 75 mins.
Increases in sync speed will depend on the percentage of the increase and will vary between a few hours and up to 5 days.
A large % increase in sync speed should see the IP profile rise within 4-6 hours, whilst a small increase may take up to 5 days before the IP profile reflects the change. BT estimates that under "Adaptive Max Logic" more than 60% of increases will now occur before they would on the old 3 day system.
Examples:-
1. - Large increase - Line dropped to a 576 sync during a thunderstorm (profile = 500), after a resync it went back up to 7616 (profile 6500). Profile increase = 6000/500 *100 = 1200% increase which should occur in 4-6 hours.
2. - Small increase - Sync increase from 7616 (profile 6500) to 8128 (profile 7150) after interleaving removed. Profile increase = 650/6500*100 = 10% which may not take effect for 5 days.
So if the OP router has maintain the same sync speed then the profile should have been changed after a few hours.
16-07-2009 10:45 AM
Quote What is "Adaptive Max Logic"?
A figment of someone's imagination perhaps ?
Has anyone actually seen it work in practice ?
16-07-2009 10:49 AM
16-07-2009 10:18 PM
I would have thought the IP profile should be inching up by now?
Seriously unimpressed with Plusnet email help too..havent even bothered to reply after 2 days. If things dont improve in the next day or two I might think of switching to another provider.
Can it seriously take up to 5 days for there to be any movement in the Profile and is there nothing Plusnet can do at there end?
Mark
16-07-2009 10:39 PM
IP profile for your line is - 3000 kbps
Actual IP throughput achieved during the test was - 46 kbps
IP Profile has miraculously zoomed up to 3000k...but what does the 'Actual IP throughput' mean? Again on any Speed tests im getting constant 250kbps, so something is still holding it back.
Any help gratefully accepted.
Mark
16-07-2009 10:50 PM
B) BT has just upped their Profile, you are still restricted by PN's profile, that will be altered to match BT's normally within 12 hours
16-07-2009 10:52 PM
Just turned the router on and off, and all seems well so far. Speed around 3000 so thats great.
Hopefully it will stay like this as browsing and trying to work online at a snails pace was driving me nuts.
Thanks to everyone who helped.
Mark
17-07-2009 1:39 PM
