IP Bump
- IP Bump
IP Bump
04-10-2010 2:26 PM
I seem to be locked at 4mbps could someone bump it up to the maximum thanks.
Message 1 of 6
(962 Views)
5 REPLIES 5
Re: IP Bump
04-10-2010 2:28 PM
4Mb matches the IP profile set for your line. What results do you get from a BT Speedtest (speedtester.bt.com)?
Message 2 of 6
(590 Views)
Re: IP Bump
04-10-2010 2:56 PM
Message 3 of 6
(590 Views)
Re: IP Bump
04-10-2010 4:06 PM
I did have this earlier in the week
http://www.speedtest.net/result/965230527.png
though i was in my training period
and i had a few drop outs due to my fuse box
Message 4 of 6
(590 Views)
Re: IP Bump
04-10-2010 4:44 PM
Hi Alxns,
As your profile has settled on 4Mb following the training your speed test result is spot on. If you maintain the higher sync speed it may well uplift but your throughput and line profile are fine as things stand currently.
Message 5 of 6
(590 Views)
Re: IP Bump
04-10-2010 4:47 PM
Quote from: Matt Hi Alxns,
Ohh ok cool then is interleaving enabled on my line? if so could i have it switched off if possible
thanks.
Message 6 of 6
(590 Views)
