IGMP - disabling
- Re: IGMP - disabling
IGMP - disabling
22-07-2013 11:37 AM
having trouble with twonky media streaming from WD MY BOOK 2TB white edition.
Spoke to twonky who advised its a setting on my router, and to disbale IGMP
http://community.twonky.com/twonky/topics/twonky_5_1_9_not_working_on_all_devices?utm_content=topic_...
Called plus net customer care who advised to post on here as it is advanced settings.
Can anyone help?
thanks
22-07-2013 3:19 PM
http://npr.me.uk/telnet.html#dnla
22-07-2013 3:21 PM
You can turn it off via telnet, though not sure if there's an option in the GUI. To turn it off using telnet run the following command at the prompt:
igmp proxy config service disabledThen hit enter
Then once that's done:
savealland hit enter again. Once you get the prompt back you can log out
Hope that helps.
EDIT: npr's commands may well work better, not sure of the difference between the two myself though I'm afraid.
22-07-2013 3:33 PM
{npr}=>igmp proxy config service disabled
Invalid option => service
Unknown command.
Firmware version 10.2.5.2.DEMO
22-07-2013 3:42 PM
22-07-2013 4:03 PM
thanks for the replies
I tried telnet commands and also returned the following
Unknown command.
Can you explain the local group service?
Is there no option to turn this off in settings via the web interface?
22-07-2013 4:07 PM
No you need to use telnet.
22-07-2013 4:22 PM
Enable Telnet in Vista or Windows 7
If using Vista or Windows 7, telnet is not enabled by default but it's very easy to do and you only need do this once.
Go to “Control Panel” > “Programs and Features” > click on “Turn windows Features On and Off” > place a tick in “Telnet Client” > click ok.
Then used
State is already enabled.
Are you suggesting another method. Im fairly techy but take it easy!!!
thanks
22-07-2013 5:00 PM
Quote from: cpettinger
thanks
Try disabled.
23-07-2013 9:35 PM
have done all the steps above but TV is still not seeing MYBOOK WORLD.
Any more ideas please?
24-07-2013 9:17 AM
No more ideas.
