I've got the wrong router! Can I flash it?
NatTheGooner
Hi
I've just been connected up to fibre but Plusnet gave me an ADSL router, so I've got not broadband.
Can I do anything with the router - it a Technicolor
thanks
Nathan
Fixes: 12
Re: I've got the wrong router! Can I flash it?
what makes you think it's the wrong router?
usually LAN port 4 is used for the fibre connection.
Plusnet Staff
Plusnet Staff
Fixes: 5
I can see that you've been in touch with our Support Team who have sent you out a FTTC router. If you wanted to, you can visit http://products.plus-payh.co.uk/firmware/ and change the firmware to FTTC if you'd like?
Chris Pettitt
Cloud Environments Engineer
NatTheGooner
I've got a Apple Mac - will it run the tool OK?
Fixes: 156
No, it's windows only - you'll either need a vm, wine or crossover to attempt to run it.
If you're not sure what these are I'd wait for the new one to turn up Smiley
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 46
It's possible to update the firmware via TFTP http://wiki.aa.org.uk/Router_-_TG582N_-_Firmware_and_Factory_Reset but how you'd go about doing that on a Mac I've no idea I'm afraid
NatTheGooner
I think I'll take the advice to wait for the new router.
I know I'll spend half a day on this and still jigger it up.
thanks very much for the info though.
