I think we've got a fault!
- I think we've got a fault!
- « Previous
- Next »
Re: I think we've got a fault!
21-10-2013 9:28 AM
When a resynch occurs, the equipment will seek t attain the best synch speed at the target SNRM (typically 6db) given the current background noise level. Thereafter if the noise level decreases, the SNRM will rise, if the noise level increases, the SNRM will fall. If it falls too lw, a resynch will be performed as described above - at a yet lower speed.
This is why if you do a controlled resynch whilst the SNRM is high, the new connection is usually at slower SNRM but higher synch speed.
The step changes in SNRM on the last graph could have been resynchs. Your line shows pronounced suspectibility to night time MW interferance. Also there s a marked level of background twitch!
@Matt, has a full copper test been done for this line? What I the AC balance like? Is an RF3 filter likely to be helpful?
21-10-2013 9:43 AM
Engineer came on Friday and fitted vDSL filter (MK 2) with RF filter built-in. He's building a case for a REIN engineer who should be coming over within a week.
21-10-2013 9:44 AM
21-10-2013 11:01 AM
Been doing some reading around the forums for you. Look at ths one - http://community.plus.net/forum/index.php/topic,111551.msg993532.html#msg993532 - note also reply 79, 110 and understand why I suggested you do not get your hopes set too high.
Not until you've had multiple visits might you start to get traction on BTOR doing a serious investigation. The pulse test is a new one on me - you might care to mention it to the next engineer.
Reply 80 is most informative - I guess my passing train REIN problem should more correctly be called SHINE!
21-10-2013 4:48 PM
Quote from: Susie Engineer came on Friday and fitted vDSL filter (MK 2) with RF filter built-in. He's building a case for a REIN engineer who should be coming over within a week.
Good news if a REIN case has been built, attentions will now be focused on this and getting it resolved.
03-11-2013 12:32 PM
I should hopefully be hearing something this coming week (*fingers crossed*).
19-11-2013 8:20 AM
19-11-2013 2:28 PM
- « Previous
- Next »
