I think my exchange now has 21CN..
- I think my exchange now has 21CN..
01-03-2012 9:43 AM
Can you please check this and let me know?
Re: I think my exchange now has 21CN..
01-03-2012 10:45 AM
This is the definitive source.
As to whether you will gain from being switched to 21CN/ADSL2+ depends on your connection, how far you are from the exchange and your sync speed etc...
In short your router's stats will give you an idea.
Those further away will gain nothing.
I understand Plusnet swap groups of subscribers over in batches following a particular exchange upgrade.
I guess they do those most likely to benefit the most first.
01-03-2012 10:54 AM
Anyway of making sure I'm in the 1st group to be switched over?
01-03-2012 10:57 AM
01-03-2012 10:57 AM
01-03-2012 11:27 AM
01-03-2012 11:31 AM
Just seen the ticket, it's due to complete on the 8th.. will my line then start another 10 day trail period?
01-03-2012 12:49 PM
01-03-2012 12:59 PM
01-03-2012 1:05 PM
01-03-2012 2:06 PM
01-03-2012 2:09 PM
However your router will need to be compatible with the ADSL2+ service. Which router is it?
01-03-2012 2:30 PM
I have 2 routers the TG585v8 and DG834GT any of these compatible?
01-03-2012 5:24 PM
01-03-2012 7:32 PM
