I think my broadband should be going faster...
- I think my broadband should be going faster...
11-12-2010 12:08 PM
I'm a new customer but have come from O2 where i've been used to much faster speeds, albeit in a different house!
We're more than 10 days in, and our broadband speed has crept up from an almost unusable 2Mbps (oh how expectations have changed!) but I still think it can be higher. O2's prediction for this phoneline is 14Mbps, and PlusNet said something similar before I joined.
I had an email the other day from PlusNet saying:
Estimated line speed: 15Mbps
Current line speed: 5Mbps
Is there anything you can do to speed things up? Why am I getting 5Mbps if I should be on 15Mbps? I understand there's some dynamic speed testing so that it settles on the best speed for the line - is this artificially limiting us?
I ran the BT Speedtest (http://speedtester.bt.com/) and got the following:
Test1 comprises of Best Effort Test: -provides background information.
Download Speed - 4040 Kbps
Max Achievable Speed - 7150 Kbps
Download speedachieved during the test was - 4040 Kbps
For your connection, the acceptable range of speeds is 2000-7150 Kbps.
IP Profile for your line is - 5000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 12.05:24.47:63.49 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
My router (Belkin F5D8633) says:
ADSL
Type Interleave Path
Status SHOWTIME
Downstream Upstream
Data rate(Kbps) 6200Kb 444Kb
Noise Margin 24 29
Output power(dBm) 120 198
Attenuation(dB) 32 11
Many thanks,
Andrew
Re: I think my broadband should be going faster...
11-12-2010 12:45 PM
The other thing is your noise margin is ridiculously high. Can you try a reboot and post the router stats again please.
11-12-2010 1:22 PM
I suspect that the line is on ADSL2+ and has been banded due to perceived instability
11-12-2010 1:47 PM
I unplugged my router and then plugged it back in again and woooooo - big change!
I now have these figures from my router:
Status SHOWTIME
Downstream Upstream
Data rate(Kbps) 16964Kb 444Kb
Noise Margin 5 30
Output power(dBm) 128 200
I did a quick speed test with http://www.speedtest.net/ and it's still at under 5...
Any idea what's going on?
Many thanks
Andrew
11-12-2010 2:17 PM
ADSL
Status SHOWTIME
Downstream Upstream
Data rate(Kbps) 10661Kb 444Kb
Noise Margin 17 27
Output power(dBm) 123 203
11-12-2010 2:51 PM
I had a look at http://www.farina1.com/adsl/ and input the details from the router which I posted above. It says
If your service provider uses ADSL2+ the maximum line speed likely is: 15650Kbps
With ADSL2+ the maximum IP throughput (result from a speedtest) is likely to be around: 13850Kbps
Your ADSL2+ speeds are likely to be in the range 12000Kbps to 15700Kbps
Andrew
11-12-2010 6:24 PM
As you've noticed the noise margin is now much higher and it looks like the DLM might have increased the target noise margin to 15dB to try to stabilise the line (stop disconnections). Unfortunately increased target noise margin goes with reduced sync speed.
Does following up the checks on this dropping connection support page help?
11-12-2010 8:51 PM
12-12-2010 1:43 PM
Many thanks for your help, we will see what higher speeds we get.
Before I read the email saying me not to do any more disconnects (!) I unplugged the router and put it in the other phone socket to see if it makes a difference (I'm not sure which is the master socket)
I got a slower speed, so I guess the previous one was the master! And I've checked all the microfilers, we have a quiet phone line etc etc
Status SHOWTIME
Downstream Upstream
Data rate(Kbps) 7250Kb 444Kb
Noise Margin 19 20
Output power(dBm) 99 205
I put it back into the previous phone socket, give it a week and see what happens
Thanks again
Andrew
13-12-2010 2:55 PM
Your BT profile is 14000 at the moment so I've just matched ours to it. You should see the difference soon. If not, then if you reboot the router via the router interface you'll see it pick up.
Jojo
