I suddenly only get internet when plugged direct into test socket
Fixes: 353
Re: I suddenly only get internet when plugged direct into test socket
@dazpiece No problem at all, especially as you don't have a phone connected. Just make sure the other half doesn't go cleaning in that area 😀
dazpiece
@jab1 and @RichardB
Thank you both so much for your help!
CliveRM
Only just seen your articles.
The best solution is to get a new master jack and check the wiring. Always better to go from socket to skt to skt daisy chain than to allow a 'star' formation going from one skt to two or more others.
This because, like radio waves, internet signals can bounce around the star causing signal echos.
Any even slightly damaged wires should be replaced. Unused skts disconnected. Get it nice n tidy. Don't mess about.
If you can't get a master, use an ordinary PRIMARY jack.
Regards
Fixes: 353
@CliveRM The OP only has a single socket, and the problem is most likely, as @RichardB said, a failed filter in the Mk.4 faceplate - the early ones, especially, are known for it.
dazpiece
@jab1 @RichardB
Ordered a new socket for a tenner as you both suggested. I replaced just the mk.4 faceplate part and now have a connection again! Thank you both you absolute legends!
Upon comparing the new faceplate with my old one, it looks like the springy metal contacts inside the broadband slot of my old faceplate are no good, as 2 of them are depressed, whereas in my new faceplate none of the springy contacts are depressed.
Fixes: 353
@dazpiece I like it when there's an easy solution.😀 Out of curiosity, how old was the socket/faceplate? Obviously not ancient, but I wonder if it was one of the early ones.
dazpiece
@jab1 not sure of the exact age but the engineer only installed this particular one around 12 months ago.
Hopefully the one I’ve just bought lasts longer!
Fixes: 353
I hope so too, @dazpiece . Mines somewhat higher up the wall in a 'safe' location, so my only suggestion can be 'avoid knocking it'Wink
dazpiece
Yeah, mine is conveniently located in the coldest corner of the house, in the corner where the outside wall and a very cold bay window meet Sad (I rent)
