I'm Stumped with Router DSL Connection info
- I'm Stumped with Router DSL Connection info
27-07-2013 11:05 PM
SNR on upload is confusing me have no clue why its so high
SN Margin (Up/Down) [dB]: 26,6 / 6,1
Output Power (Up/Down) [dBm]: 12,9 / 0,0
DSL Connection
Link Information
Uptime: 0 days, 22:29:41
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 443 / 8.115
Data Transferred (Sent/Received) [MB/GB]: 188,59 / 1,94
Line Attenuation (Up/Down) [dB]: 21,8 / 41,5
Loss of Link (Remote): -
Error Seconds (Local/Remote): 1.041 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 13 / 2.306
HEC Errors (Up/Down): 6 / 6.976
DSL Connection
Link Information
Message 1 of 2
(575 Views)
1 REPLY 1
Re: I'm Stumped with Router DSL Connection info
28-07-2013 12:51 AM
Your upstream sync speed is capped at 448kbps so the high noise margin reflects that. I suggest you raise a ticket at https://www.plus.net/wizard/?p=wizard&page=22883&wizard_id=38 requesting that your upstream sync speed be uncapped. That will probably more than double the upstream sync speed with a upstream noise margin of 6dB.
David
Message 2 of 2
(282 Views)
