I left.......why?
- I left.......why?
I left.......why?
23-11-2007 10:45 PM
So I left....and was told via email what I was going to miss - BT Vision etc - but no one addressed why my speeds and connection were so bad.
So Im with BT. I swore years ago that I wouldnt touch them with my piss if they were on fire. And their CS sucks. And I have lodged 8 complains since 13/11 regarding their adverts. Its like peeling and onion - but thats a different story. Fact is.....my connection averages 6 MBPS. Its solid as a rock and is sooooo much better than PN. Why?
Re: I left.......why?
23-11-2007 10:47 PM
23-11-2007 10:49 PM
BT would put you on maxDSL with a new order
23-11-2007 11:01 PM
23-11-2007 11:20 PM
A fixed 2Mbps has some advantages in the sense that you get 2Mbps (exchange contention allowing) whilst with "up to" 8Mbps service BT will monitor what they think the quality of your line is.
AFAIK If you play games a lot, then your ping times can suffer under Max ADSL whilst they would be better on a 2Mbps service.
23-11-2007 11:25 PM
23-11-2007 11:39 PM
And why should I be victim of the "existing customer" syndrome and fail to qualify or be alerted to the better deals?
24-11-2007 12:23 AM
24-11-2007 12:28 AM
now that was premium rate!
24-11-2007 12:52 AM
24-11-2007 9:58 AM
24-11-2007 9:59 AM
When we originally started the upgrades to Max we intended to upgrade everyone, for the very reasons you have stated.
However, there was a much higher fault rate initially than we (or any other ISP) expected, so we changed the process to become opt-in.
As jelv said, we put this change in the newsletter, and have followed it up with emails to the customers who are still not on Max over the last couple of months.
If you get 6MB on a BT connection you would get this on a PlusNet connection also.
Regarding the speed issues in general, I'm not sure when you were having problems but we have certainly been more pro-active with adding new bandwidth when required, so those issues are not seen anymore.
24-11-2007 10:20 AM
Quote from: Mand
Oh Really, speed issues in general are not seen anymore. Excellent, hold on what's this
Oops
24-11-2007 10:46 AM
You really should use this site to be the judge :- http://www.mybroadbandspeed.co.uk - possibly combined with the speedtester on ThinkBroadband.
Of course, if these yield low results, you should always see what a BT Speedtest shows.
24-11-2007 11:06 AM
What I was referring to specifically was slow speeds due to congestion on our network, we add new central capacity pretty much every few months now in line with growth, whereas we weren't so proactive in doing this in the past.
If you could run a BT Speedtest for me I'd be happy to investigate this for you.
