I keep having to activate auto login.
esseff
I set auto login to remain active for a year each time, yet after only 3 weeks or so, I have to activate it again. It's quite annoying. Why should this be?
1 REPLY
Re: I keep having to activate auto login.
Do you access your account from several computers and have yo set auto-logon on each? If so, that is your problem. Auto-logon is only support to work from a single PC.
If the above does not apply, clear out your PN cookies and try again.
