I have no problem with down sync speed but the on the up I do
- I have no problem with down sync speed but the on ...
24-03-2015 7:28 AM
DSLStats Monitor shows up sync 571 kbps
BTw speed test reads " Upstream Rate IP profile on your line is - 0.83 Mbps".
All the stats for downstream are pretty well what would be expected. Explanation why this discrepancy exists will be welcome.
Re: I have no problem with down sync speed but the on the up I do
24-03-2015 7:34 AM
24-03-2015 11:32 AM
Is this what is needed?
adsl info --stats
adsl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason: 8000
Last initialization procedure status: 0
Max: Upstream rate = 676 Kbps, Downstream rate = 9040 Kbps
Bearer: 0, Upstream rate = 571 Kbps, Downstream rate = 8253 Kbps
Link Power State: L0
Mode: ADSL2+ Annex A
TPS-TC: ATM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 3.2 11.5
Attn(dB): 46.0 26.4
Pwr(dBm): 0.0 12.8
ADSL2 framing
Bearer 0
MSGc: 59 12
B: 128 17
M: 1 4
T: 2 4
R: 10 12
S: 0.4982 3.9763
L: 2232 169
D: 64 8
Counters
Bearer 0
SF: 58398988 346946
SFErr: 12060 296
RS: 3296900925 1272068
RSCorr: 7091077 20759
RSUnCorr: 420623 0
Bearer 0
HEC: 295441 750
OCD: 463 0
LCD: 463 0
Total Cells: 1226684946 1272325806
Data Cells: 201354492 13153660
Drop Cells: 0
Bit Errors: 17818618 47971
ES: 11912 576
SES: 181 4
UAS: 688 353
AS: 945463
Bearer 0
INP: 1.00 2.00
INPRein: 0.00 0.00
delay: 8 8
PER: 16.19 17.89
OR: 32.11 8.04
AgR: 8253.45 577.17
Bitswap: 338351/338383 930/943
Total time = 22 days 23 hours 24 min 6 sec
FEC: 17057772 137818
CRC: 28158 1373
ES: 11912 576
SES: 181 4
UAS: 688 353
LOS: 3 0
LOF: 26 0
LOM: 37 0
Latest 15 minutes time = 9 min 6 sec
FEC: 12362 23
CRC: 2 0
ES: 2 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 12035 33
CRC: 8 0
ES: 5 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 23 hours 24 min 6 sec
FEC: 760696 835
CRC: 1552 11
ES: 493 6
SES: 13 0
UAS: 256 0
LOS: 0 0
LOF: 0 0
LOM: 5 0
Previous 1 day time = 24 hours 0 sec
FEC: 600528 750
CRC: 857 21
ES: 458 11
SES: 3 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Since Link time = 10 days 22 hours 42 min 11 sec
FEC: 7091077 20759
CRC: 12060 296
ES: 5557 133
SES: 53 1
UAS: 268 16
LOS: 0 0
LOF: 0 0
LOM: 12 0
24-03-2015 11:46 AM
As a comparison this is from my connection which more or less matches/explains your numbers
Noise Margin: 9.5 dB
Bandwidth: 888 kbps
Attenuation: 26.4 dB
Except this is my downstream which is way lower/worse than yours
Noise Margin: 6.0 dB
Bandwidth: 3927 kbps
Attenuation: 49.5 dB
One thing to try is the test socket as it just may be something in your house such as a filter giving problems
24-03-2015 1:08 PM
Are you on 2 or 2+? I'm on 2+ with a ~ 3 dB target margin downstream, so with the attenuation I couldn't have a complaint. You say my upstream margin is high, so what would you reckon it ought to be? Just curious. TBH I'm thinking, if the reduction in up sync (which doesn't tie in with BTw) could have happened when I had some problems needing sorting out via Mwbytes gurus. All was Ok then, but DSLStats data has been time wiped.
Would a gateway hop be useful or a resync? With the controversy over slow downs....?
24-03-2015 1:20 PM
Normally I would expect 6db or 9dB but with an 888kbps limit because it is interleaved
Gateway hop wouldn't help as it is your sync rate which is the problem
You could ask for a reset to 6dB upstream noise margin
24-03-2015 2:12 PM
24-03-2015 2:17 PM
I was referring to the upstream noise margin only - nothing to do with the downstream margin
24-03-2015 6:39 PM
Bullet bitten and router has been restarted and now have
SNR (dB): 2.9 9.4
Attn(dB): 46.0 26.4
Thanks!
25-03-2015 2:00 PM
