turn on suggestions
I dont understand what PING is - and is 156ms bad?
- I dont understand what PING is - and is 156ms bad?
28-08-2013 6:42 AM
Having tried the BT speedtest thre times in 3 minute window I get PING times of 156, then 64 then 127 Ms.
I was under the impression that low PING is better - certainly fr gaming.
My previous ISP (Eclipse) provided fast PING times of around 10 -15ms.
W
thanks in advance
W
- hy is Plusnet PING so variable and slow?
What is PING anyway?
How do I get a low PING out of Plusnet without spending hours on the phone?
thanks in advance
1 REPLY
Re: I dont understand what PING is - and is 156ms bad?
28-08-2013 9:53 AM
Do you need to have a fast ping, i.e. do you use VoIP telephones, or do online gaming ?
What result do you get with http://www.pingtest.net/
