I can't access Npower website.
victaylor
Is anyone able to confirm (or otherwise) whether they can connect to the energy website http://www.npower.com, please?
I can't,  I have sent several PING tests and they all time out.
Npower support and Plusnet support say it's working fine.
Mystified, so wondered if anyone else could shed any light... Sad
This issue previously reported last year - see http://community.plus.net/forum/index.php?topic=134408.msg1176152
35 REPLIES 35
Strat
Fixes: 565
Re: I can't access Npower website.
Accessed and logged in ok here.
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
It's working here, and via http://downforeveryoneorjustme.com/
Unlikely, but does entering the login page directly at https://www.npower.com/At_home/Applications/Npower.Web.Login/login.aspx work?
 Tony T
npr
Fixes: 9
Don't rely on ping tests, it can means the site doesn't reply to pings.
I can access the site fine but my pings still time out.
victaylor
Quote from: plusnettony
No,  I still just get page not available for the site.
npr
Fixes: 9
Can you access it using the following IP address in the browsers address bar?
http://46.18.118.60
Gus
If you browser has manual cookie control/search, delete all cookies for npower.com.  I had that same issue not long ago with amazon.co.uk with Opera, it would load with Firefox/waterfox/chrome but not Opera until I deleted all cookies for it.
FTTP 500 regrade from Tues 28th November
victaylor
Quote from: npr
http://46.18.118.60
No. still getting  'This webpage is not available’
victaylor
Quote from: Gus
I have cleared all my cookies and cache.  Still getting  'This webpage is not available’
Thanks to all for help so far but still a problem.
npr
Fixes: 9
Have you checked if the site has been blocked by Plusnet's Safeguard?
https://portal.plus.net/my-account/safeguard/
Have you tried accessing the site form a different PC / tablet / phone on the same network ?
deathtrap
I too can't access this site using it's dns hostname,(unless i use a proxy) but using its IP address works for me i am not using plusnet's dns and don't use safeguard as there is enough of the internet blocked without using that
I did notice that it is routed via level3
30FTTC06
Fixes: 4
all good here using plusnet dns and others.
[tt]
; <<>> DiG 9.8.3-P1 <<>> @212.159.6.9 npower.com
; (1 server found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 54799
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 2, ADDITIONAL: 0
;; QUESTION SECTION:
;npower.com. IN A
;; ANSWER SECTION:
npower.com. 300 IN A 46.18.118.60
;; AUTHORITY SECTION:
npower.com. 60669 IN NS dns4.rwe.com.
npower.com. 60669 IN NS dns1.rwe.com.
;; Query time: 47 msec
;; SERVER: 212.159.6.9#53(212.159.6.9)
;; WHEN: Tue Apr 28 21:12:06 2015
;; MSG SIZE  rcvd: 86
[/tt]
Silly one, but have you tried dropping that ip just incase ?
ejs
Aspiring Hero
Fixes: 25
I can access www.npower.com - but the TCP traceroute does go a bit weird at the end:
# traceroute -q 1 -N 1 -T -p 80 www.npower.com
traceroute to www.npower.com (46.18.118.60), 30 hops max, 52 byte packets
1  gateway (192.168.0.1)  1.410 ms
2  lo0.12.central12.ptn-bng01.plus.net (195.166.128.230)  20.392 ms
3  irb.12.ptw-cr01.plus.net (84.93.249.33)  19.877 ms
4  195.99.126.182 (195.99.126.182)  20.747 ms
5  core2-te0-15-0-13.ealing.ukcore.bt.net (109.159.255.90)  24.755 ms
6  62.172.103.143 (62.172.103.143)  20.709 ms
7  t2c4-xe-10-1-0-0.uk-ilf.eu.bt.net (166.49.168.101)  21.163 ms
8  xe-10-3-0.edge3.London1.Level3.net (195.50.124.17)  21.550 ms
9  ADVERSOR-LI.edge3.London1.Level3.net (195.50.124.66)  21.302 ms
10  *
11  46.18.118.60 (46.18.118.60)  21.781 ms
12  46.18.118.60 (46.18.118.60)  21.589 ms
13  46.18.118.60 (46.18.118.60)  22.113 ms
14  46.18.118.60 (46.18.118.60)  25.707 ms
15  46.18.118.60 (46.18.118.60)  21.783 ms
16  46.18.118.60 (46.18.118.60)  37.173 ms
17  46.18.118.60 (46.18.118.60)  22.134 ms
18  46.18.118.60 (46.18.118.60)  21.635 ms
19  46.18.118.60 (46.18.118.60)  22.736 ms
20  46.18.118.60 (46.18.118.60)  31.391 ms
21  46.18.118.60 (46.18.118.60)  30.284 ms
22  46.18.118.60 (46.18.118.60)  30.813 ms
23  46.18.118.60 (46.18.118.60)  29.605 ms
npr
Fixes: 9
Quote from: ejs
Yes, and strangely ping 46.18.118.60 results in time outs.
victaylor
Quote from: npr
I do not use Safeguard.
Yes,  I can access Npower on my tablet PC over the same network.
