I bought a Hudl... and can't connect it!
- I bought a Hudl... and can't connect it!
03-10-2013 11:00 AM
Brought it home last night all shiny and new. Now it's covered with increasingly angry fingermarks. When I put in the password (have tried the obvious one, very carefully, as on the bottom of the router, plus anything else that might be construed as a 'password'), it then tells me it's 'authenticating'. This goes on for some time until (if you're lucky) it says 'authentication failed'. Router is a Thompson Gateway and I've had no problems in the past getting laptops online.
Who should I blame? Router? PlusNet? Tesco? or me?
Re: I bought a Hudl... and can't connect it!
03-10-2013 11:08 AM
03-10-2013 12:33 PM
Let me know if the below link is helpful from Tesco Tech Support
http://ttselectrical.custhelp.com/app/answers/detail/a_id/3552/related/1
03-10-2013 12:43 PM
I am sure you have followed the instructions for connecting your Hudl to a network, but just in case, instructions are below.
How do I connect my Hudl to the Internet?
Tap 'All Apps' and go to 'Settings'.
Under 'Wireless and Networks' select 'Wi-Fi'.
Ensure the Wi-Fi slider is set to 'ON', the device will automatically scan for nearby networks.
Select your home network from the list.
Enter your password.
Tap 'Connect'
Your device will then connect to your network.
Your details will be remembered, and your Hudl will automatically connect to that network whenever you are in range.
03-10-2013 1:28 PM
03-10-2013 5:47 PM
03-10-2013 6:07 PM
03-10-2013 6:37 PM
04-10-2013 9:32 AM
04-10-2013 11:04 AM
Does this tablet support 5G wi fi?
04-10-2013 12:54 PM
It says it has dual band wifi in the product description
http://www.tesco.com/groceries/Product/Details/?id=278352324
09-08-2016 8:10 PM
10-08-2016 10:05 AM
10-08-2016 6:33 PM
You didn't notice that the messages before the empty one were 2013, did you?
Phil
11-08-2016 12:08 PM
