I am on an up to 8 but only get 2
pierre_pierre
I am happy with my 2 but would like to know why I only have a 2 meg line.
upload speed 7712  download 449
noise                  14.                    27
line att                18                    10
power                19.8                  11.8
I am only 800 metre from exchange,
every thing else says only 2 meg
BT Speed test
Test1 comprises of Best Effort Test:  -provides background information.
    IP profile for your line is - 6500 kbps
    DSL connection rate: 448 kbps(UP-STREAM)  7712 kbps(DOWN-STREAM)
    Actual IP throughput achieved during the test was - 5243 kbps
Dont tell me to connect to master socket, I havnt got one.but all lines are correctly filtered
Fixes: 162
Re: I am on an up to 8 but only get 2
That's showing around 5, not 2. Where are you getting the 2Mb speeds?
 Chris Parr
 Plusnet Staff
pierre_pierre
a) from Kitz
Exchange: Braintree.  BT Code: EABNT
ADSL enabled : June 29, 2001
dsl Max enabled: March 30, 2006
SDSL enabled : Not Enabled
21CN due : no info
Distance:- Direct:    794 metres
    (appx)* By Road: 2.41 km
BT Line Speed Estimation Other Broadband Technology & LLU Providers
adsl button Fixed ADSL:  2048 kbps (2 Mb)
adsl button DSL Max :  7000 kbps (7 Mb)
from My Broadbandspeed
Today 10:19  1958 kbps (245kB/s)  376 kbps (47kB/s)  Share
Saturday 12:48 1845 kbps (231kB/s) 377 kbps (47.1kB/s) Share
Friday 18:54 1692 kbps (212kB/s) 380 kbps (47.5kB/s) Share
Thursday 13:51 1934 kbps (242kB/s) 363 kbps (45.4kB/s) Share
Fixes: 62
can you try this test http://www.speedtest.bbmax.co.uk/
Fixes: 162
What speeds does a different speedtester show? Such as this one or this one?
 Chris Parr
 Plusnet Staff
Fixes: 62
Chris - your second link needs correcting
Fixes: 162
Fixed, thanks.
 Chris Parr
 Plusnet Staff
pierre_pierre
Oldjims test looks identitcal to PN speed test
Think Broadband
Speed Test Results
Date 25/02/08 10:35:58
Speed Down 1860.13 Kbps ( 1.8 Mbps )
Speed Up 374.69 Kbps ( 0.4 Mbps )
Port 8095
Server speedtest1.adslguide.org.uk
Speed test . net
James
Pierre,
BT Speedtester giving higher speed results than other tests is often an indication that your rWin and MTU settings could do with some tweaking.
I'd recommend having a look at the video tutorial which you can find here:
http://www.plus.net/support/broadband/troubleshooting/rwin_video.shtml
pierre_pierre
upped my rwin from 8760 gt5o 100,000
wow
Date  Download Speed  Upload Speed
Today 12:32 5078 kbps (635kB/s) 380 kbps (47.5kB/s) Share
Today 11:41 2064 kbps (258kB/s) 379 kbps (47.4kB/s) Share
Cheesy Grin
James
Oh yes.
pierre_pierre
Your link obviously worked, I have been looking around the help files for several week, and always ended up a dead end, never found any links to outside PN, perhaps I should start playing games and find out more, Only one spanner for me on that one, despite having been into computer for 40 plus years.
pierre_pierre
now look what youve done James
Today 16:27  6256 kbps (782kB/s)  381 kbps (47.6kB/s)  Share
Today 15:34 5236 kbps (655kB/s) 380 kbps (47.5kB/s) Share
  Smiley Wink Cheesy Grin Shocked Cool Roll eyes Tongue Kiss
James
Sorry Smiley
I can change it back to 2Mbps if you'd like? Cheesy
