I am done with the supplied plusnet router and have bought an TP-Link Archer C50 to improve the wifi
jules0405
The TP-Link Archer C50 arrives tomorrow.  I have my plusnet broadband login details.  I have never replaced a router before so I am assuming the new router is going to have a page where I can type in this login information.  Is this correct?
1 REPLY 1
Fixes: 418
Re: I am done with the supplied plusnet router and have bought an TP-Link Archer C50 to improve the
From a quick Google search it looks to me like the C50 is a router, not a combined modem/router like the Plusnet hubs.   If you want to use this you will need a separate modem.
Alternatively you could switch off your Plusnet modem/router wireless and use the C50 as an access point. See the manual. https://www.tp-link.com/uk/home-networking/wifi-router/archer-c50/?utm_medium=select-local
