Huge packet loss on specific destinations
oliverb
Re: Huge packet loss on specific destinations
I got someone to traceroute in the other direction and it seems to report an entirely different route via as8218.eu
2  a9k2-1041.dc3.poneytelecom.eu (88.191.1.185)  0.960 ms  1.268 ms  1.350 ms
3  213.152.30.6 (213.152.30.6)  0.258 ms  0.349 ms  0.350 ms
4  xe2-2-0.tcr1.gs.par.as8218.eu (83.167.56.176)  0.726 ms  0.761 ms  0.759 ms
5  xe1-0-0.tcr1.thn.lon.as8218.eu (83.167.63.230)  9.012 ms  8.875 ms  9.001 ms
6  lonap-gw2.plus.net (5.57.80.155)  40.852 ms  40.933 ms  40.836 ms
Still a bad hike in response times.
deadman2020
This has been going on for a couple of weeks or more now. What can be done about this? I should NOT have to connect only from 11pm-2pm to be able to use my connection for this? How do I go about getting this resolved?
thesawdust
PlusNET can only inform the provider. Maybe you could contact them?
oruvin
PlusNet can change routing tables to avoid bad routes.
oliverb
Is as8218.eu the backbone provider?
Kelly
Fixes: 9
We've mailed proxad but they've not responded.
Kelly Dorset
Ex-Broadband Service Manager
AndyH
Quote from: oruvin
I don't think it's as simple as pressing a button, or they would have done it already.
A quick google search of proxad shows them to have a history of problems...
oruvin
Of course it isn't as simple as we think, but if there is no simple solution to fix a problem, more complicated solutions should be used.
oliverb
Things are looking up: quite a good service this evening. Shame I was watching telly instead of gaming so didn't benefit.
Target Name: 195-154-168-239.rev.poneytelecom.eu
        IP: 195.154.168.239
  Date/Time: 1/22/2014 8:57:46 PM to 1/22/2014 9:57:32 PM
Hop Sent Err  PL% Min Max Avg  Host Name / [IP]
1  240  0  0.0  0 217  4  my.router [192.168.3.254]
2  240  2  0.8  16 570  58  lo0-central10.ptn-ag04.plus.net [195.166.128.193]
3  240 240 100.0  0  0  0  [-]
4  240  2  0.8  15 490  50  xe-8-2-0.ptw-cr02.plus.net [212.159.0.118]
5  240  4  1.7  16 583  46  ae2.ptw-cr01.plus.net [195.166.129.4]
6  240  20  8.3  16 496  50  linx-6k-1.routers.proxad.net [195.66.224.191]
7  240  2  0.8  24 481  57  bzn-crs16-1-be1102.intf.routers.proxad.net [212.27.51.185]
8  240 240 100.0  0  0  0  [-]
9  240 240 100.0  0  0  0  [-]
10  240  3  1.3  25 493  57  45x-s44-1-1039.dc3.poneytelecom.eu [88.191.1.178]
11  240  3  1.3  24 476  53  195-154-168-239.rev.poneytelecom.eu [195.154.168.239]
AndyH
I hope that is sarcasm...
oliverb
Looks like the traffic has been rerouted via as8218 now. From what I've seen elsewhere that's probably a more stable route, and similar to the route seen when traced from the game server to me.
        IP: 195.154.168.239
  Date/Time: 1/25/2014 12:45:09 PM to 1/25/2014 12:59:55 PM
1    60  0  0.0  0  3  1  my.router [192.168.3.254]
2    60  0  0.0  15 351  41  lo0-central10.ptn-ag01.plus.net [195.166.128.190]
3    60  60 100.0  0  0  0  [-]
4    60  0  0.0  15  45  18  xe-5-2-0.ptw-cr02.plus.net [212.159.0.106]
5    60  0  0.0  15 107  20  lonap1.thn.lon.neotelecoms.com [5.57.80.210]
6    60  0  0.0  23  31  24  xe1-3-0.tcr1.th2.par.as8218.eu [83.167.63.231]
7    60  0  0.0  23  58  27  xe0-0-0.tcr1.th2.par.as8218.eu [83.167.56.177]
8    60  60 100.0  0  0  0  [-]
9    60  0  0.0  24  81  29  45x-s44-1-1041.dc3.poneytelecom.eu [88.191.1.186]
10    60  0  0.0  24  31  25  195-154-168-239.rev.poneytelecom.eu [195.154.168.239]
Kelly
Fixes: 9
Is it performing better on the application you were using?
Kelly Dorset
oliverb
Yes it is noticeably better now.
deadman2020
My ticket says they have rerouted. But it's still showing Proxad with packet loss here.
deadman2020
It's back to being horrendous packet loss tonight.
