Hudl 2 and Plusnet authentication problem
- Hudl 2 and Plusnet authentication problem
27-11-2014 8:52 PM
Grateful for any help please!
Re: Hudl 2 and Plusnet authentication problem
27-11-2014 10:23 PM
To be is to do - Kant
do be do be do - Sinatra
27-11-2014 11:07 PM
27-11-2014 11:13 PM
Peter, my router is quite old (5 years plus) and I don't have Fibre Broadband. May have something to do with it?
Night night...
27-11-2014 11:20 PM
Edit typo, should have said 585 not 565
28-11-2014 8:40 AM
Is yours failing to see the signal or failing to connect when the password is entered? I assume of course that Wifi is switched on in the Hudl 'settings.'
(Afraid that's the only constructive question I can put to you - the above is about the sum total of my Wifi knowledge to date!)
28-11-2014 8:46 AM
Quote from: jeanners49 .......... my router is quite old (5 years plus) .......
was the reason I asked if it was a 585 modem/router. If I understood and remembered correctly something I'd seen/heard - the HUDL2 requires a wireless 'n' connection which the 585 doesn't have?
Edit: having checked, that's not the case, see later post.
28-11-2014 8:57 AM
28-11-2014 10:24 AM
28-11-2014 3:37 PM
28-11-2014 5:36 PM
28-11-2014 5:49 PM
28-11-2014 5:51 PM
28-11-2014 6:08 PM
Does the router's SSID show up in the list of available networks in Settings|Wifi
What encryption does the Hudl show in the Settings|Wi-Fi for your SSID?
How many characters does your SSID have?
What wifi channel is your router using? Try 1, 6 or 11 - Avoid 12 & 13
28-11-2014 6:24 PM
