Hub has detected a problem with my internet connection
KrazyyOne
Hi, after ordering broadband on the 21/10 we finally got a message after 22:00 tonight to say our broadband is good to go. So we've turned on the router and it just flashes orange and when we turn on our devices we get a message saying our hub has detected a problem with our internet connection. Tried rebooting and factory resetting etc but no luck. Any help gratefully received. It's very frustrating.
47 REPLIES 47
Fixes: 334
Re: Hub has detected a problem with my internet connection
@KrazyyOne Welcome to the forums. Are all cables fully home?
KrazyyOne
@jab1 they are fully home.
Fixes: 334
OK. I don't think this could be the issue, but is the username in the format of 'myusername@plusdsl.net'?
KrazyyOne
I am not using a user name at the moment it is a case of logging into the local 192 network and the router cannot see internet.
Fixes: 334
I don't quite understand that. If you are logged into the Hub (Hub2, presumably), what is the username displayed on the picture below?
Fixes: 528
@KrazyyOne is the router connected to your master socket   ?
Do you have a dual socket ?
Have a look at the Troubleshooting help here https://www.plus.net/help/broadband/connection-troubleshooting/
@jab1 if its flashing orange, it's got no dsl sync, the username won't matter yet. It will be setup@plusdsl.netbanyway as it's not been able to auto configure
Fixes: 334
Not thought of that, @MisterW  - not had my second coffee yet. 😀
KrazyyOne
The router is connected to the socket where previous router was
Fixes: 334
@KrazyyOne But is it an old style single socket, or the current Master socket 5C with a Mk.4 faceplate?
KrazyyOne
@jab1 it has 2 sockets but not the line
Fixes: 334
So it is a 5C/Mk.4 . What 'line' is missing?
KrazyyOne
@jab1 The line that signifies it's a master socket. Spoke to someone from plusnet who suggested doing what you said earlier on about user name but that either hangs on connecting or disconnects
Fixes: 334
Don't suppose you could post a photograph, I'm still a little confused?
Fixes: 457
@KrazyyOne
Going back to step 1, have you got a telephone dial tone?
