Hub flashing pink - no internet
Fixes: 530
Re: Hub flashing pink - no internet
I'm also wondering (grateful for advice) whether the reason there isn't a bigger local uproar about the outage is because many nearby houses have gone full fibre rather than fibre to the cabinet only and this no longer passes through that cabinet, so they're not affected?  Is this a possibility and backs up the apparent lack of urgency to fix it?
@Logan72 you are correct, Full fibre connections don't go via the cabinet so will not be affected by the cabinet damage.
As to whether that has an implication on urgency to fix, only Openreach could answer that, and they're not going to...
Logan72
Nothing's happening is it?  Photo attached.
Would anyone know what kind of work could be, or have been, happening since 30 nov if this is the situation at the cabinet?
Is there a way of me contacting Openreach to enquire about progress/express my frustration?
Cheers all.
Logan72
Complaint logged with Openreach.
James30
Fixes: 32
@Logan72 - Hi, I've tried to find out more from my side but I can only see that there is "Dslam Damaged" that we already know and a new ERT of 22/12/23.
James - Plusnet Sheffield
Logan72
Thanks @James30.
Service now restored.  I saw the cabinet finally being worked on 19/12 and my broadband/internet is back today.
Grateful for advice on process to obtain credits/rebate for the 21 days loss of service.
Thank you.
James30
Fixes: 32
That's good news then. The system will process auto compensation for total loss of service to your account 30 days after it's the fault is closed so keep an eye out.
