Hub 2 flashing no wifi.
insussex
It's 23:00 and the hub is flashing orange after working perfectly prior. Done the reboot, check cables etc. No body at plusnet to take my call. Lost my wifi too meaning cctv all down, don't understand as wifi should still work without Internet.
2 REPLIES 2
bigdavethehorn
Re: Hub 2 flashing no wifi.
Same issue here, 23:00 exact
Fixes: 137
@insussex @bigdavethehorn
Has your service restored?
If not I would suggest reporting a fault https://www.plus.net/help/report-a-problem/
