Hub 2 and ADSL
trymyluck
Hub 2 and ADSL
My daughter is in the process of upgrading her broadband from ADSL to FTTC.  She has just received anew Hub 2 by post.  Does she need to wait to get a message that FTTC is set up and running before she sets up the new hub or can she set up the hub and use it on the existing ADSL broadband?
4 REPLIES 4
willcutforth
Fixes: 18
Re: Hub 2 and ADSL
Hey there @trymyluck she should be able to plug it in and use it straight away. There shouldn't be any issues but let us know if there is.
 Will Cutforth
trymyluck
Re: Hub 2 and ADSL
Many thanks Will.   Shall get my daughter to give it a try
willcutforth
Fixes: 18
Re: Hub 2 and ADSL
Let us know how you get on Smiley
 Will Cutforth
trymyluck
Re: Hub 2 and ADSL
I can confirm that my daughter's Hub 2 is working ok on her ADSL broadband connection with a download speed showing 17.4mps, an upload speed of 1.4mps and a response time of 18ms. The accuracy of the speed test site might be questionable of course. She is awaiting a call from Plusnet to say when the FTTC service to be set up.
