Hub 2 Arrived and installed, but getting slow speeds, can the profile for my connection be wiped ?
- Hub 2 Arrived and installed, but getting slow spee...
Wednesday
My Hub 2 Arrived and i've installed, replacing my suspected failing hub 1 using ADSL but now i'm getting slow speeds, (7mb) can the profile for my connection be wiped ? as it would contain data from my failing hub 1, and why I believe the connection is being throttled from its usual 20mb down to 7mb.
Thanks for your help!
Jrice
1 REPLY 1
Re: Hub 2 Arrived and installed, but getting slow speeds, can the profile for my connection be wiped
Wednesday
@jrice I suspect your connection has been 'managed' by DLM due to a possible fault. If you can attach a screenshot of your Technical Log - Information page (with the user ID obscured), and your exported event log .csv output, someone on here can probably advise the next steps.
