How would I remove a possible Stealthed transparent proxy service?
Interested
Tried to send a free text message using one the free UK text messaging services and it said you are unable to send texts in your country it is only for the UK!
I tried a test I found via google which suggested I could have a Stealthed transparent proxy as the serial number didn't  change and when I re-loaded the page it was aging in minutes not seconds.
Helpful advice would be appreciated.
Many Thanks
pwatson
Re: How would I remove a possible Stealthed transparent proxy service?
I think you've probably mis-diagnosed the problem.  Plusnet do not use proxies, stealthed or otherwise.
It's far more likely that your current IP address has been deemed to be in the USA as some geo-location databases hold old (incorrect data).  Does your address start 146.xxx.xxx.xxx by any chance?  Try disconnecting and reconnecting from Plusnet and see if your IP address changes and the problem goes away.
See this thread for details
Fixes: 101
It does.
Customer and Forum Moderator.
Interested
IP address now updated seemingly on its own.
But at least all Ok now and free text messages working again.
Thank you.
Interested
Wondering if my IP address has switched back to one which was previously from the U.S.A again, Having several location problems. Tried reconnecting router but it didn't work.
Interested
Yes it has switched back to 146..... but how do I rectify? Thanks.
Log off via the router interface, wait a few minutes, then log on again.
