How will my IP profile change?
- How will my IP profile change?
- « Previous
- 1
- 2
- Next »
Re: How will my IP profile change?
21-12-2014 9:35 AM
Did a speedcheck and got the same results as yesterday, but then on the BT further diagnostics I could see my IP profile had gone up to 19.3Mb. Logged into the router and disconnected / connected to the internet - now I'm getting the 19Mb
Thanks for all the helpful advice chaps
When I get back from my holidays I might have a play around with the openreach modem + netgear router combo. Think that might get my upstream to 1.5Mb? (I see some Thomson's only get 1Mb max upstream, though that might just be ADSL and not 2+). My line attenuation reads even lower up than it does down!
Never thought I'd see such a good result from copper broadband - well chuffed.
Message 16 of 20
(297 Views)
21-12-2014 2:05 PM
Message 17 of 20
(297 Views)
21-12-2014 3:05 PM
You won't get 1.5Mb up - the best you can hope for is around .850 - .950, unless you go to Annex M, which will a) use some of your downstream bandwidth and b) cost you more.
Message 18 of 20
(297 Views)
21-12-2014 10:16 PM
Ah I see. Is that the same thing I saw in the telnet options (and can therefore now safely ignore)?
It's been a while since I had a connection I didn't have to share - looking forward to some lag free fragging sessions on the old counter strike
Message 19 of 20
(297 Views)
29-12-2014 4:49 PM
You can safely ignore that in telnet (sorry for the much delayed response!).
I've got to say that spotting the modulation was very good from ejs, it probably would have escaped my attention at first glance!
Message 20 of 20
(297 Views)
- « Previous
- 1
- 2
- Next »
