How will I obtain Network Key/Password if using own router?
- How will I obtain Network Key/Password if using ow...
07-06-2013 9:16 PM
I am due to be connected to Plusnet broadband tomorrow, my previous Sky broadband connection has been turned off today. When I signed up with Plusnet I said I would use my existing Sky router. It says that they send network key/password details with the new router, so how do I get them when I am using my own router. I am unable to find any details on the member support on the main plusnet site.
Many Thanks,
TE
Many Thanks,
TE
Message 1 of 5
(760 Views)
4 REPLIES 4
Re: How will I obtain Network Key/Password if using own router?
07-06-2013 9:26 PM
once activated your details should be here https://portal.plus.net/my.html?s=0&action=refresh_browser
Message 2 of 5
(438 Views)
07-06-2013 9:34 PM
Thanks for that information. I did come across that page earlier and it's 'not active' as yet - as expected, but the password is eight '*'s for "security reasons", so how am I going to find out what it actually is?
Cheers,
TE
Cheers,
TE
Message 3 of 5
(438 Views)
07-06-2013 9:36 PM
At some stage when you signed up with PlusNet you had to put in your preferred password on the application form, it will be that one
Message 4 of 5
(438 Views)
07-06-2013 9:39 PM
Great - I know which one that is, thanks for your help!
Message 5 of 5
(438 Views)
